Links
Old 08-23-2004, 01:46 PM   #1 (permalink)
Default Relays Relays wher are you?
On a 95 Disco 5-speed left drive US model vin SA. I have a factory parts catalogue and on page J17 shows passenger footwell hinged bracket. It shows 5 relays laying flat (i found) and 3 relays vertical, all i see is the mounting tabs, no relays to be seen. They are for power wash, ABS warning and ABS pump, where are they located? They are not in the LH and RH footwell A post area. Any help please, Carl....................o&o>...................
beemer is offline   Reply With Quote
Old 08-24-2004, 05:04 PM   #2 (permalink)
Default Relays
According to my manual, the relays are found behind the passenger side fasica. However, this manual is for right hand drive cars, so yours might be behind the driver's fascia.
However, you state that you have found mounting tabs but no relays, which is odd. Does your car actually have ABS? Follow the brake pipes from the master cylinder. If they head into a box with four brake lines coming out, then you do have ABS. If they simply split into the two braking circuits, then you do not have ABS, which might explain the absense of relays :-)
There should be three ABS relays controlling braking system load, braking system pump and braking system warning. I am curious as to what has prompted you to look for these relays in the first place, though.
Kevanch is offline   Reply With Quote
Old 08-26-2004, 05:48 PM   #3 (permalink)
Default ABS relays
Kevanch, it's a left hand drive 95 Disco 5-speed with ABS. The ABS light would go on and off, reset wheel sensors (one was 1/16" out). Now light stays on. Been reports that the warning light and ABS relays can fail, but i can't find them. Thru pictures from the factory workshop manual they are not around, as well as the parts catalogue, i have both. Thanks, Carl........o&o>....
Old 08-27-2004, 08:02 AM   #4 (permalink)
Carl:
This is not specifically related to your thread,but where can I find a parts catalogue for a Disco l and ll?Let me know.
Thanks,
Carlos
Carlos is offline   Reply With Quote
Old 08-27-2004, 01:29 PM   #5 (permalink)
beer drinking member
dent's Avatar
Carl, it *should* be on the left side..weird that you have ABS and the relays are not there... did you buy your rig new or used?
take care
sam
dent is offline   Reply With Quote
Old 08-28-2004, 02:32 AM   #6 (permalink)
Default missing relays?
dent, this is a second owner vehicle, new to me in 1-2000 from a doctor at end of 5yr. 60,000 mile lease. Because it was a clean highway vehicle and 5-speed i had to have it. I wanted a challenge, i got it. The parts catalogue shows a swing down bracket under the glove box and shows three relays (the missing ones). This is LHD NAS 95 Disco. Thanks, Carl.........o&o>.........
Old 08-28-2004, 02:49 AM   #7 (permalink)
Default parts catalogue
Carlos, the catalogue was given to me by a person in parts department. He became a good friend, i helped him on BMW motorcycle (i've got 9 bikes) and he helped me. I believe they are not to given to the public. Between the 577 page catalogue and a workshop manual i've got a little advantage.
Carl......................o&o>.................... .................................................
Old 08-30-2004, 06:15 AM   #8 (permalink)
dent's Avatar
Carl, got almost the same truck as yours... 96 for me... will take the panel off this weekend as i need to change the o2 sensor and the plugs so will take a look and see what i got there and will take some pics too...
btw... the shaft broke on my gear box and had to swap it out... damn those gear boxes are hard to find and is *not* cheap
take care
sam
Old 08-31-2004, 11:32 PM   #9 (permalink)
Default gear box, big $$$
Dent, within the next two weeks i'm going to pull the trans, 5-speed because it's been a town vehicle and the synchros are tired. Also the transfer box will be gone thru as it wines, more like a bearing noise than gear wine. Must change the clutch disc and pressure plate, it's been a shaker since the new 4.6 28,000 miles ago. I hope the output splines ok, the dealer said i had the new gear. I'll have to sell the kids to pay for the parts, Ha Ha! Carl....o&o>.....
Old 09-01-2004, 07:36 PM   #10 (permalink)
Carlos
I have 6 versions of RAVE discs, which show a LOT more info than you need. I make copies for $5ea, or $6ea if you want the discs to look almost original. Click my signature and look in the Spare Rover Parts photo album.
Walk softly & carry a BIG SIX!
Steve83 is offline   Reply With Quote
