Links
Old 04-17-2008, 10:18 AM   #1 (permalink)
phyltered's Avatar
Default Replacing the Shift Indicator assembly
Hello everyone, I have a 97 Discovery and I am trying to replace the Shift Indicator assembly. I have figured out how to remove the console, switches etc, but how does the shift knob seperate from the shaft so I can put it through the new unit? I have taken off the top of the shifter knob (the cap), and have found no answers. Please advise?
Thanks, Phil
phyltered is offline   Reply With Quote
Old 04-17-2008, 01:58 PM   #2 (permalink)
daniels disco
Hey there Phil., ...lets see... I took mine apart a few months ago.. o.k., remove the cap, the spring-loaded button on the drivers side slides out, you might have to put it netural or reverse to do this, ( don't lose the spring and remember how the parts come out) then i believe theres a nut that has to be removed.
once that has been done, apply a bit of force from the bottom up on the shift knob and it will eventually free itself.
I dont have my disco here today, so i cant go out and verify. good luck, dan
daniels disco is offline   Reply With Quote
Old 04-17-2008, 03:19 PM   #3 (permalink)
phyltered's Avatar
Sweet. I will give it a shot after work tomorrow, I'll let you know how it goes... Thanx D!
Old 04-19-2008, 12:38 PM   #4 (permalink)
phyltered's Avatar
hey everyone, i can't figure out how to remove the retaining clip that holds the shift indicator shaft in place, so i can remove the knob. i dont want to break it... any suggestions?
manual shift and sport shift lights blinking? deepsessions Discovery Series II 1 08-15-2007 03:45 AM
manual shift and sport shift lights blinking? mnmike Discovery Series II 6 12-19-2006 07:38 AM
Gear Shift OSIYEZA Discovery Series II 3 12-14-2006 11:30 AM
First - Second Shift Problem OSIYEZA Discovery Series II 2 09-20-2006 03:04 AM
Hard Gear Shift After Transfer Case Overhaul royemaun Discovery Series I 2 08-20-2005 08:10 AM
