» Sponsors
» Sponsors
Old 10-09-2009, 03:32 PM   #1 (permalink)
Al J
jennina1's Avatar
Default Revving - WHERE do those vacuum lines go?
95 Disco after warming revs, & stalls at idle.
I have replaced the IAC, VSS, cleaned MAF,
replaced both O2 sensors, water temperature sensor,
no help. After the first O2 sensor was replaced (44 code was evident)
I cleared the code and it came back...
I think it is a vacuum problem.
There is a vacuum line that is between the plenum and firewall, near
the stepper motor / IAC - it is currently plugged and does
not go anywere.
As well, the vacuum switch that opens and closes the water flow to and from the heater core is not hooked up to anything.
I have been all over the forums, RAVE cd, and everywhere else I can think to find out where these vacuum lines go to...
Can someone that has a 3.9 please help me?
jennina1 is offline   Reply With Quote
Old 10-10-2009, 09:23 AM   #2 (permalink)
ihscouts's Avatar
Near stepper motor, probably cruise control. I don't know about the heat control, maybe someone else does.
97 D1 SD
ihscouts is offline   Reply With Quote
Upper intake vacuum lines, where do they go? highoctane Range Rover Classic 2 10-24-2008 04:56 PM
Replace Vacuum Advance - 1990 RRC Irons1990County Range Rover Classic 2 07-29-2008 08:35 PM
1995 Disco Distributor Vacuum lines Question/ See Picture AtlasEngr Discovery Series I 4 01-10-2007 08:29 AM
Vacuum Lines Brian Davies Discovery Series I 4 09-16-2005 11:17 AM
Automatic Trans Cooling Lines Irvin Range Rover Classic 0 01-18-2005 08:24 PM
