To all who replied....Thanks. Newest Readers Digest version: Presure wash under the hood resulted in some sort of electrical problem that fixed itself after it sat and dried out for 2 days. It started up and idled perfect for about 15 seconds and then all HELL broke loose. Misfiring, smoke, sputtering,
. I really don't know where to start. Before the pressure washing incident I had already replaced the plugs and also put a new alternator(generator) on it. I have the repair guide on disc, and I have been reading several of the post that are titled "misfire" but can anybody point me in a direction to begin trouble shooting????![]() |
Rebuilding Rover
x2 on the codes that will tell us a direction to head.
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://snhlr.org/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
I did the same thing to my truck, only I got no fuel. My problem ended up being a wet ECU that was causing the fuel pump to die. While I hate giving advice on a problem that could be anything, my solution was to clean and dry the ECU. Mine turned out to be full of salt from 7 years of New England winters so its a good thing I caught it when I did.
"A deep respect for tradition allows vision for liberation from stagnation." Colin's Toys: 1972 Series III 88" 1997 Discovery XD 1993 RRC (Gone to a better place, goodbye old friend) 1983 Stage 1 109" 2002 Trek 4500 2005 Necky Looksha Sport 2007 Rans Rocket 2007 Honda Ruckus |
Rebuilding Rover
1998 and stock going from his previous thread
Thanks to all of you very much! I am a novice, shade tree mechanic that loves to do the basics, but I'm not a good "trouble shooter." It is a 1998 Disco I bought from a couple that lived in Maine but relocated down to SC a couple of years ago and it sat for an undetermined period of time in their yard. I would say probably 6-8 months. It has 192,000 miles on it, so I basically bought it for the "Toy" value. It is bone stock.
The salt concept sounds logical because I have seen a ton of salt residue under the frame, etc. Codes? Whats the best (i.e. most cost effective) way to get the codes? |
Rebuilding Rover
autozone and like parts stores will scan them for free.
Or go to said parts store and drop a few bucks to buy a OBD II Scanner and do it yourself. I have one like this Actron OBD II AUTOSCANNER / Code Reader w/ CAN Coverage: Compare Prices, View Price History and Read Reviews at NexTag
#9 (permalink) |
daniels disco
hi, i now own a '94 disco, but my previous disco was a '98 and i did the exact same thing to mine... on day one of ownership.!! MY problem was the under hood ecu. water pools up in the wiring harnes at the contacts.
to repair., remove the ecu (located on the pass. side wheel well by the washer fluid canister)its a flat black box with 2 wiring harnesses going to it. I used a q-tip to remove the pool of water, then sprayed the contacts with wd-40. replace.. and avoid high pressure washing in that area again. dan |
#10 (permalink) |
![]() I got the ecu off, one longer black connector, single red connector and a smaller black connector. The smaller black connector (male side) on the ecu itself had water in it. There was green buildup all over a couple of the connectors and I followed your advice and used q-tips to get most of the water out. I used air pressure to push some of the water out and I believe I got most of it. I went deeper into the ecu and didn't see any evidence of water on the controll boards, so I quickly buttoned that right back up! The wiring harness (or female side) also had more water then the ecu connector. I tried my best to get out what I could. I left the harness haning upside down so maybe gravity will do some of the work. I am going to let both the ecu and wiring harness just air out for a while. Thanks so far for the help! By the way, did you ever have problems with the tachometer not working? I have a new battery and alternator, installed less than a week ago. I noticed that when I turn the engine over it moves upward about a quarter of an inch and just sits. If you look at it real close you can see movement, sort of like it might be stuck. Any advice? |
#11 (permalink) |
hey just read your tread.... i did the Exact same thing as you and had the exact problem..... what min endedup being was water in the distribtor from the pressure washer...was all fine then bam!!! running rough misfireing coughing farting... the whole works... try popping off your cap then take off the yellow cap lol that says do not remove...blow the whole thing out good with air then see if there is any build up on the contacts if soo clean them.... this worked great for me.... when i reassembled i die greased everything... i have since washed my motor 4 or 4 time and havent had another issue yet...... hope this helps....
91 G.D.E. project/daily winter driver 93 BMW 325i project/daily summer driver:SOLD: ![]() 00 BUELL cyclone custom ![]() http://www.snhlr.org/
#12 (permalink) |
I'm calling you SUPER DAN
. Seemed to do the trick. For good measure, I grabbed the wifes hair dryer and blew some hot air into the wiring harness. All is well and I have returned to rule in Disco land........for now. It acutally seems to have a bit more "pep." Thanks to all who helped out.Marc ![]() |
#13 (permalink) |
daniels disco
Hey., I am glad that worked out for you !! "SUPER DAN" I like that !! sorry i cant help you with the tack problem., i am sure someone here knows the answer to your problem. dan
| Thread Tools | |
| Display Modes | |
| Detailing 101: Common Question and Answers, What and Where to buy stuff + Technique | David | General Land Rover Discussion | 50 | 04-27-2008 09:08 PM |
| Pressure Wash under hood | marcnat | Discovery Series I | 6 | 04-07-2008 10:38 AM |
| [ALL] Detailing FAQ's + Technique | Disco | Tech & DIY | 0 | 01-08-2007 03:31 AM |
| 1995 Range Rover Classic LWB w/ NEW engine | Serg | Land Rover Vehicles | 3 | 11-21-2005 06:33 PM |
| 1995 Range Rover Classic LWB | Serg | Land Rover Vehicles | 7 | 05-04-2005 12:31 PM |
