Old 03-22-2008, 07:34 PM   #1 (permalink)
texaninmass's Avatar
Gallery: 2
Default second battery on a LR
Has anyone installed a second battery before on Disco 1? If so where did you mount it?
Thanks Anthony
texaninmass is offline   Reply With Quote
Old 03-28-2008, 08:51 PM   #2 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Wink
Same place , just move some of the stuff around. You will have to decide the type of batterys (Optima or otherwise)and which charging system you want installed.
Discovery Series II
Arb Dual Battery Systems
Recommended Dual Battery Systems, Auxiliary Battery Chargers
http://www.overland.co.za/Dual_Batte...al_Battery.pdf
second-battery-lr-16816.jpg  second-battery-lr-16824.jpg  second-battery-lr-snorkel_0003.jpg
inert facts.
Old 03-29-2008, 07:18 AM   #3 (permalink)
For a D1, I think the best place id by the air box, easy fit and balances out the additional weight.
Old 04-10-2008, 07:42 AM   #4 (permalink)
Gallery: 2
Adam in NYC USA,
Thank you very much for the info! Sorry I did not reply back ealier, I must have missed the auto notification from the web site. The PDF is perfect for direction on installation info.
Disco Mike: After looking at the pictures I agree that the airbox location is the best place.
Thanks again for your help it is very helpfull.
Anthony
Old 04-10-2008, 07:17 PM   #5 (permalink)
Why would one want to install a second battery?
Phototone is offline   Reply With Quote
Old 04-11-2008, 06:10 AM   #6 (permalink)
Gallery: 2
Hi Phototone,
There are several reasons to have a second battery. My primary reason is that I have a winch that draws a lot from the battery.
With the proper battery management system connected you can use 1 battery for auxiliary equipment and keep the primary battery for running primary systems or you have the ability to run the batteries in parallel if desired. The other reason for me is that I run a tremendous amount of other electronic equipment (2 1000 watt amps, 4-7 inch monitors, 2 DVD players, 1 DVD/GPS player, a CB and a 400 watt inverter) that I would prefer to to keep on the secondary battery.
Mike and Adam: Here is the listing for the Luna Management system I found-
EQUIPT Expedition Outfitters - Intelligent Split Charging Kit
After looking at this I am thinking of using the Blue Sea Management system, the Luna runs $375.00 as apposed to this system that runs $150.00.
The link below shows the system and has a great audio description of the product:
West Marine: "Add-A-Battery" Dual Circuit System Product Display
I realize there are differences in the systems but for the price I think it is a good trade off.
Any feedback would be appreciated.
Anthony
Old 04-11-2008, 03:59 PM   #7 (permalink)
Ok, I See Why.
Old 04-13-2008, 01:51 AM   #8 (permalink)
Wortho's Avatar
Front of airbox is ment for Aux battery, you can actually get a 110ah defender battery in there by moving the power sterring resovoir around.
Over here Dual battery's are one of the first things done to a vehicle for running fridges and lights and for back up starting as you tend to be a long way from help over here. Sure power smart solinoid is the best way to go, we install these all the time at work, you should be able to get it pretty cheap over there to as it's a Yank product. You could also go to an ARB store and get a "kit" with every thing ready made to just plug and play(for a D1).
Smoke me a Kipper, i'll be back for breakfast!
Wortho is offline   Reply With Quote
Old 04-13-2008, 12:07 PM   #9 (permalink)
Gallery: 2
Hi Wortho,
Thank you for the info, I spent time today researching the Sure Power solution and I it looks like a great product, I also came across another solution called "Hellroaring" I have listed the links below that show installation and pricing info and wonder what you think about this. I have not made any decision on what one to go with so the verdict is still out on which one I will go with.
I did have a question about the installation on the second battery. In looking at the area in front of the air box, how do you move the input tube in front of the airbox? Or where do you move it to?
Hellroaring Battery Isolator Combiner, BIC-75150A
Hellroaring Battery Isolator/Combiner notes for 4 Wheel Drive dual battery applications
Anthony
Door not unlocking with key problem bruinfan90241 Range Rover P38, Mk III and Range Rover Sport 3 03-15-2007 01:12 PM
Battery Problem Searcaigh Discovery Series II 2 09-30-2006 12:28 AM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
Battery Light kdkg Range Rover Classic 6 10-06-2005 05:05 AM
