Old 03-02-2005, 05:40 PM   #1 (permalink)
Default Service Engine Light 1999 Discovery SD
I have seen some posts concerning the "check engine" light but not on the "service engine" light. Had the reader module hooked up and it came back with no codes. Can anyone tell me how to reset the light on this model?
Thanks in advance for any assistance.
Patrick52 is offline   Reply With Quote
Old 03-03-2005, 05:56 AM   #2 (permalink)
not sure on the d2s but its a little box under the pass seat or in my case under the passenger kick panel that you just put a small metal object into the hole and it touches the 2 metal prongs and its reset...hope that helps ya find it.
rov'n is offline   Reply With Quote
Old 03-03-2005, 07:30 AM   #3 (permalink)
My Disco has a CD player in access panel under the passenger seat. I will look to see if there is anything else in that area. Thanks.
Old 03-03-2005, 08:17 AM   #4 (permalink)
beer drinking member
dent's Avatar
check passenger side kick panel, not under the seat
take care
sam
dent is offline   Reply With Quote
Old 03-03-2005, 08:49 PM   #5 (permalink)
Banned
I think the cover says TRW on it. It should be in the pass kick panel. Remove the sticker, and there should be a paper clip size hole. Turn the key to ACC, and touch the two prongs with a metal object. Sometimes, you need to remove the cover.
Hank is offline   Reply With Quote
Old 03-04-2005, 06:35 AM   #6 (permalink)
Thumbs up Thanks.
Guys, that did it. Thanks again.
Patrick
Old 05-25-2005, 10:08 PM   #7 (permalink)
Mod. --- I'm watching you
darkknight1999's Avatar
Patrick was it behind the passenger kick panel??
-John
Some of my favorite quotes:
"what you do in life, echo's in eternity..."
"death smiles at us all... all a man can do is smile back..."
1999 Discovery II SE-7
darkknight1999 is offline   Reply With Quote
Old 07-20-2005, 11:47 AM   #8 (permalink)
JamesVee's Avatar
I recently ran into the same problem. I found the switch. Touched both of the metal prongs together with a paper clip, with the key on the ACC and fully on. And I still have a check engine light. I have a 99 Disco S1, switch was behind passenger kick panel.
Check out my websites: Family Trophies and Africa Pictures
JamesVee is offline   Reply With Quote
Old 07-20-2005, 11:52 AM   #9 (permalink)
4x4 Adventure Gear
John C's Avatar
Did you check for codes (at Autozone or your an OBDII reader)?
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 07-20-2005, 12:03 PM   #10 (permalink)
JamesVee's Avatar
No, I did not check for codes.
