Old 05-12-2008, 03:49 PM   #1 (permalink)
Default shaky brake pedal ABS?
Have a 97 Discovery & going over bumps could feel brake pedal vibrate and also seems like a relay is activating. Have to step on barake pedal harder to stop doing it more frequently & also sometimes ABS light comes on ANy ideas?
onguard is offline   Reply With Quote
Old 05-13-2008, 01:13 PM   #2 (permalink)
Yes, that is the ABS system. It may be malfunctioning.
Phototone is offline   Reply With Quote
Old 05-17-2008, 11:33 PM   #3 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Check your brake fluid level. take the D1 on a test drive. Do stopping manuevers in a empty parking lot. Tap light then accelerate then brake harder and harder. Does it stop safely to you? If not have the pads front and back inspected for proper thickness. Also have the shop check for air bubbles and have the system bled.
Had the pedal sink to the floor on the highway in stop and go traffic. It turned out that the front driver brake pad had broke in two.
inert facts.
Old 05-18-2008, 07:09 AM   #4 (permalink)
Before you do all that check the abs senors. They come loose and/or get dirty.
jhmover is offline   Reply With Quote
Hard Brake Pedal Kevin88RRC Range Rover Classic 5 04-17-2008 03:10 PM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 04:45 PM
Brake Pedal...weird vibrations when pushed boxer Range Rover Classic 1 12-29-2006 04:45 AM
Long Brake Pedal Syndrome? PCrover Discovery Series II 21 06-29-2005 10:12 AM
Hard brake pedal.. Serg Range Rover Classic 3 03-27-2005 09:03 PM
