Old 10-03-2005, 09:04 AM   #1 (permalink)
These pretzels are making me thirsty
Private Iron's Avatar
Default Shifter Illumination
Hey I am having trouble with the lights around the automatic shifter that tell ya what gear you're in. Sometimes they are on, sometimes not. I mean, I know how to shift into drive and reverse without the light to know what gear I am in, but it's nice to have. Anyway, I'm sure I just have a connection loose, but how do I find out. I tried messing with the plastic casing around the bottom on the shifter, but it didn't easily come off, so I didn't know if there was a trick to it or if I need to be more forceful, or if I should start my search somehwere else. Any suggestions? Have a '98 LE btw. Thanks
I love it when a plan comes together.
'98 Disco LE- bone stock, but with aspirations
Private Iron is offline   Reply With Quote
Old 10-03-2005, 07:21 PM   #2 (permalink)
RoverChic's Avatar
Sounds like maybe you need new shifter tape, or possibly fluid has some how ingested itself inside the shifting film/shifter causing a short of some sort. You can normally find this on Ebay for relatively cheap.
2006 Range Rover Sport HSE Rimini Red
2001 D2 CDL
1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired)
1988 RRC SWB ('Silver Bullet' Retired 05/98)
RoverChic is offline   Reply With Quote
Old 10-04-2005, 06:26 AM   #3 (permalink)
I guess I'll just try harder to get the casing around the bottom off. I didn't want to break anything, but I suppose I gotta get it off if I want to fix it. Thanks for the advice.
Old 10-04-2005, 01:51 PM   #4 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Arrow
Pry the bezel from the back and it should come off. Lift up and you will be able to remove and inspect the bulbs. The receptacles are hidden and will need to be pried.
I suggest when you have the chance to purchase the LED versions of those bulbs. That way this will probably be the last time you will ever have to replace those bulbs.
Old 10-04-2005, 02:57 PM   #5 (permalink)
Cool, I'll go see what I can do. Thanks for the help.
Old 10-05-2005, 05:42 AM   #6 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
Try subjecting the truck to some vibration. My shifter illumination never worked from day 1, and I'd given up on it ever working, but after my 2nd offroading trip, it magically started lighting up like it was supposed to
FelixLockhart is offline   Reply With Quote
Old 10-06-2005, 04:18 AM   #7 (permalink)
Once you do get in there, I would suggest replacing the both bulbs on either side of the shifter. I initially only did one, then it bugged the hell out of me that one side was significantly brighter than the other. Went back in and changed the other...
'99 Disco I
'04 Disco II
Stephen99D1 is offline   Reply With Quote
Old 10-06-2005, 06:46 AM   #8 (permalink)
Yeah, I changed both of them. Looks great. Thanks for the help guys.
