Good day y'all
Could someone tell me what size the oil pan bolt is?? IE"" the drain plug" Iwanna start doing my own maintance Last time in for change they didint even grease it LOSERS.. And what are your recommendations on changing it.. I do mine every 2000 Its a 95 disco 3.9 auto.. And anything Else i should look for on general maintance when I do my oil changes .. Thanks all you guys are a life saver.. Eric Last edited by GentrysRover : 02-01-2005 at 05:41 PM. |
The oil drain bolt on my '94 3.9 disco is 17mm. I have found that most work on the discos is pretty easy and does not require a whole lot of tools. I wait 'til around 3000mi to change mine, but no vehicle ever fail because the oil was changed too often. Not a bad idea to check brake pads and front end parts at that time.
billmcweld |
okay, where are the lube points on this vehicle. I can't find any. I see all the linkages and there's little the boots to keep the grease in, but there's no grease fittings that i can tell. any help is appreciated.
99 disco ii w/ cold climate and SLS. |
#5 (permalink) | |
okay, what's the oil capacity. I just changed my oil and it appears to be about 5 qts, although i could swear I read somewhere it was 7qts.
sorry for all the simple questions, i've got the service manual on order. so they should stop soon.
| Thread Tools | |
| Display Modes | |
