Sound coming from front after brake job - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 06-16-2005, 10:39 AM Thread Starter
Support Our Troops
Quoted: 0 Post(s)
Okay I had to have the front rotors, pads and calipers replaced on my 97 Disco SE7. The place that did the work always does a great job and is usually very good about not messing things up.
But, 2 days after they did the work I hear a clicking type sound coming from I believe the front driver side wheel area. Then it stopped and now a few days later it came back, but only after driving for about 1/2 hour. Today no noise as of yet. Anybody have any clues? I plan on taking it back to them, but with the noise coming and going not sure if they will be able to hear what it does.
apbtpetey is offline
post #2 of 10 (permalink) Old 06-16-2005, 10:41 AM
Banned
Hyde's Avatar
Quoted: 0 Post(s)
Pads need proper shimming. What you are more than likely hearing is the backing of the pads clicking against the caliper. Very common problem with non OEM brake jobs.
Hyde is offline
post #3 of 10 (permalink) Old 06-16-2005, 12:44 PM Thread Starter
Support Our Troops
Quoted: 0 Post(s)
So I should take it back then right. Is it bad to drive with them doing this? I have to drive appox 100miles before being able to go to the shop tomorrow
post #4 of 10 (permalink) Old 06-16-2005, 02:23 PM
Banned
Hyde's Avatar
Quoted: 0 Post(s)
It wont hurt anything other than your nerves. Yes, if someone else was paid to do the brakes, I would take it back and tell them that the pads need to be shimmed.
Hyde is offline
post #5 of 10 (permalink) Old 06-16-2005, 04:35 PM
Quoted: 0 Post(s)
It sounds like the anti-vibration shim behind the pad has been left out,causing the pad to rattle.
aussie disco97 is offline
post #6 of 10 (permalink) Old 07-16-2005, 12:15 PM
Quoted: 0 Post(s)
I too have a pop that comes from the Driver-side when braking. When I press the pedal, about a second after I hear/feel a small pop. Is this the same problem you're having apbtpetey???
01001010 is offline
post #7 of 10 (permalink) Old 07-16-2005, 06:21 PM Thread Starter
Support Our Troops
Quoted: 0 Post(s)
Sorry doesnt sound like the samething as what mine does. I get a clicking type sound. If I hit the brakes it stops.
I havent had time to take it back to the place. So I am just dealing with the noise. I cant hear it if the windows are up. I talked the place and they said just bring it in when I have time and they'll look at it.
post #8 of 10 (permalink) Old 08-20-2006, 10:30 AM
Quoted: 0 Post(s)
Noises
I have a 96 Disco that I found had no oil in the spindles causing noises in the front end. Cheaper to put in a little oil than most other things. God Bless the Southland.
Rebelman is offline
post #9 of 10 (permalink) Old 08-20-2006, 06:39 PM
drewclare25's Avatar
Quoted: 0 Post(s)
i have the same problem...the inner brake pad is sliding, and clicking everythign the wheel goes around. If i get OEM brake pads, will it be fixed...or is a clip broken or something?
Best 4x4xFar
97 Green D1
3" BB springs
pro comp es9000 shocks
32x11.50 BFG Mud Terrains
15" american racing steel wheels
flowmaster 40 series dual pipes
mantec snorkel
drewclare25 is offline
post #10 of 10 (permalink) Old 08-29-2006, 12:51 PM
Jeffrey
Scort007's Avatar
Quoted: 0 Post(s)
Wheel Noise
Same here I found that the top bolt was not put on and it may have fallen off while driveing. I had it replaced. You might want to check and make sure that the bolts are tight. And Shimms may be you issue also. When metal get hot it expands.
Scort007 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
