Old 07-30-2006, 07:26 AM   #1 (permalink)
Default Steering colum play
Hey all,
Where the steering shaft comes through firewall to gear box without steering wheel locked how much play shpuld there be?? I can move mine slightly..Is that normal or should I replace it?? Let me know your thoughts
Thanks Eric
95 d1-
Gentrysrover95D is offline   Reply With Quote
Old 07-30-2006, 08:21 AM   #2 (permalink)
Sounds normal, what sort of a problem are you having?
Old 07-30-2006, 09:46 AM   #3 (permalink)
Mike,
I have the famous DEATH JITTER When I hit a bridge joint or frost heave steering wheel shakes badly.. Thinking about panhead/radius arm bushing up front Any other suggestions Steering stablizer is new ,tire and shocks less than 10000 mile let me know
Eric
Old 07-30-2006, 10:21 AM   #4 (permalink)
Eric,
How about the pre load on your swivel joints?
Other then that, check the tie rod ends and all arms, also the adjustment on your steering box.
If the stabilizer is very old will will not help control your problem, first of course is find the looseness.
Old 07-30-2006, 04:34 PM   #5 (permalink)
pre load on your swivel joints? How do you know if they need adjusting and how do you do it?? Let me know
Thanks Eric
Old 07-30-2006, 05:35 PM   #6 (permalink)
Originally Posted by Gentrysrover95D
Thanks Eric
That is a big job and if it were the problem, a mechanic would need to do it.
Why not find a small Rover shop and let them take a look.
