Old 07-28-2006, 09:36 AM   #1 (permalink)
texasrover's Avatar
Default Steering stabilizer?
What should I expect to feel when this is worn out. As is, it walks a little and the steering wheel has a lot of feed back with grooves in the road. I can feel it pulling the wheel and almost fight to correct it then usually as I get it corrected the grooves change enough to make my correction and over correction. I am flirting this being pulled over for suspected drunk driving.
Does this sound like a stabilizer?
That is not a leak! That is undercarriage rust inhibitor.
98 Discovery
Old 07-28-2006, 09:37 AM   #2 (permalink)
texasrover's Avatar
BTW... it tracks just fine... with no real pull on smooth roads.
98 Discovery
Old 07-28-2006, 09:42 AM   #3 (permalink)
Banned
I ran about 10k mile without one. Then, I started to get a "shake" in the steering wheel, so I install a new one. That did not correct my problem. I got the tires re-balanced, and all was well.
So, I'm not too sure you'll "feel" anything. I'd say it does help a little with bump-steer, though
Hank is offline   Reply With Quote
Old 07-28-2006, 10:43 AM   #4 (permalink)
daway's Avatar
i just had my rrc t-rods, aliment, balanced/rotated and acouple of other things done because it was pulling to the right and it helped out alot but i still have alittle play in the steering wheel on my '93 factory steering dampers. it drive straight as it could ever get (roads r never that perfect) i just order a ome damper at lrr for $60 which is a great deal! so next wk when i put it in i will tell u if it make a differnts. i think it will. i am a picky person about my steering and pulling. aaron
1993 RRC, county LWB "bertha"
myroverworld
