still need help no start 95 disco
95 disco 3.9 auto w/92k miles, quit while driving at hwy speed. cranks, 34 lbs pressure in the fuel rail, strong spark at the plugs. quit 50 miiles after fill up so i assume not a bad gas problem. normally very reliable truck. lived in the desert its entire life so no rust or corrosion problems. the only other problem i had is the shifter clip came loose and the trans was stuck in reverse and was towed a short distance at low speed. ran fine after that was repaired until this no start issue. anything other than the ecu come to mind.
