Old 01-14-2006, 12:01 PM   #1 (permalink)
bluemax09
Default Stripped Lug Nuts. Help
ANY Suggestions? 97 Disco SE7
Also, the new "LR" Lugs are $25 a piece. I found an all steel set on expedition exchange for $40 for 20 of them. They are made for the steel rim but will they work on the stock rim that I have?
Also another thought I had was to cut the aluminum cap away from the lugs to get to the actual nut and try it that way. Suggestions?
Thanks
bluemax09 is offline   Reply With Quote
Old 01-14-2006, 12:37 PM   #2 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
the lug nuts EE has only work with the steel wheels. they are too small for the alloys.
Arsell
My Car Domain Site
llesra is offline   Reply With Quote
Old 01-14-2006, 12:47 PM   #3 (permalink)
Roads?...Where we're going, we don't need roads...
keptin's Avatar
I had mine replaced by the guys that stripped them.....ouch (for them)! $20/lug.
If you cant do that and must pay yourself, here are new ones at britishatlantic.com;
https://www.roverparts.com/ProductLi...umber=NRC7415A
$179 for 20.....about $9/lug
Or you could cut the caps off your old ones. Those caps are just on for decoration for the most part.....if you use a die grinder or similar you could just cut them off and then the lugs would turn into 26mm or something......it would be the cheapest way, and would prevent them from being stripped again.
Josh Shapiro
DII
Photos at www.kep1.com
