Stuck on rear brake disc replacement - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 09-19-2009, 02:58 PM   #1 (permalink)
Default Stuck on rear brake disc replacement
Hi,
I thought I would save some money and replace the rear discs and pads in my 95 disco....
Everything was going fine, following the Rave manual (aside from some very stubborn bolts) until I got down to the part where you have to bend back the lock washer tabs. (rear hub assembly in the manual) For the life of me I couldn't think of a way to get them off that wouldn't fubar the lock washer. Is this a part that gets replaced as a part of the rear disc replacement or am I missing the right tool for the job?
Any help would be greatly appreciated.
I've put it all back together again. I would rather not take it to a shop but I will if it needs it.
1995 Discovery Series 1
scooby is offline   Reply With Quote
Old 09-19-2009, 05:18 PM   #2 (permalink)
mbrummal's Avatar
the lock washer gets replaced any time it is removed.
This site sucks balls.
mbrummal is offline   Reply With Quote
Old 11-26-2010, 05:55 PM   #3 (permalink)
Originally Posted by scooby View Post
Hi,
I thought I would save some money and replace the rear brake disc and pads in my 95 disco....
Replace the tab washer and then the outer nut and tighten it. Bend the tab washer inwards to lock the first nut and then outwards to lock the outer nut. Clean the old gasket off the drive flange and fit a new one. Replace the drive member and turn the disc until the holes line up and replace the bolts.
Brandon Mitchell is offline   Reply With Quote
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 22 11-10-2009 05:47 PM
rear end yolk removal and replacement, now a whining noise? deadboy1977 Range Rover Classic 9 06-29-2009 12:02 PM
Rear Bumper Replacement Recommendations BamaDisco03 Discovery Series II 51 02-19-2009 06:21 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 09:41 PM
brake pad replacement, warning lights? ozlandy Discovery Series II 1 10-09-2005 09:18 PM
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
