Old 05-05-2006, 12:05 PM   #1 (permalink)
natvboy's Avatar
Default sunroof leak
I am getting water in the headliner above the driver seat. Does the DI have a problem with the sunroof leaking or is it only mine?
Robert
natvboy is offline   Reply With Quote
Old 05-05-2006, 01:40 PM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
There are a few threads on this site about it...sadly.. you are not alone!!
Old 05-06-2006, 09:48 AM   #3 (permalink)
It shouldn't be that big a deal to correct, as with any sun roof they have drain pipes that can plug, you might want to start there and see it water is flowing thru.
Old 07-03-2006, 01:13 PM   #4 (permalink)
I would rather die on my feet then live on my knees.
Discodude19's Avatar
my rear sunroof is leaking the same way is that the same deal?
Discodude19 is offline   Reply With Quote
Old 07-03-2006, 01:20 PM   #5 (permalink)
Yes, sounds like you have a drain plugged up in the rear sun roof.
Old 07-03-2006, 01:32 PM   #6 (permalink)
01001010's Avatar
Gallery: 15
I've got the same leak only the passenger side... my solution: CHOPPING THE ROOF!!!
JC...
Old 07-03-2006, 04:24 PM   #7 (permalink)
Aaron98Disco's Avatar
Man I wish mine didn't even have sunroofs.. Its not like I use them.
Current: 1998 D1
Ex: 1992 RRC (long gone)
Aaron98Disco is offline   Reply With Quote
Old 07-04-2006, 05:29 AM   #8 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
My rear sunroof was leaking last year for a few days until I could get a look at it. After I finally opened it up to take a look I found a piece of pinecone that had fallen from the tree above where I usually park it had landed on the rubber seal when it was opened. When the roof was closed it breached the seal and allowed water to come in. When I removed the debri and closed the sun roof the leak stopped. I felt really stupid for not checking it sooner...
9dawgs
'99 Discovery I
'99 Chevy Astro 4X2 w/4" Lift (family truckster)
17' Basstracker w/40HP Mercury
11' Jon Boat w/numerous antique outboards
9dawgs is offline   Reply With Quote
Old 07-04-2006, 06:12 AM   #9 (permalink)
Geobloke's Avatar
I wish I had a sunroof! very handy things! Might see about modd'in Eva to have one. Wonder if it'll fit under my roof rack?!?!! out with the measuring tapes...
1992 K-reg 200TDI Defender 90 (Eva)
There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill
Geobloke is offline   Reply With Quote
Old 07-04-2006, 05:22 PM   #10 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Wink Dont forget the silicone spray.........
spray the stripping and the inside lip of the sunroof. Makes it nice and watertight for the next few storms. I do it so I wont get a surprise splash when I brake.
Adam in NYC
PS I use CRC slicone spray. Use the good stuff.
inert facts.
Adam in NYC USA is online now   Reply With Quote
Old 11-13-2007, 07:40 AM   #11 (permalink)
How does one get access to the drain pipes? Is this visible from just opening the roof? What is the best way to clear them?
jlonigro is offline   Reply With Quote
Old 11-23-2007, 07:14 AM   #12 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
I posted originally that I had debri in my sunroof seal causing a leak. That was the case about a year ago. Recently the leak got so bad that as in the first post on this thread, I had water sloshing around in the headliner. Further investigation revealed the sunroof seals were shot. If you climb in the vehicle with the sunroof in the closed position and are able to see daylight between the glass and the rubber seal, you need to replace it. I found a guy on Ebay who sells them for 40USD each. These are factory seals. Install is very easy and took me about 15 minutes for front and rear sunroofs. These seals are shipped from the UK and are well worth the price. Just type in "Discovery Sun Roof Seal" in the search and it should take you right to his site. Hope this helps.
9dawgs
'99 Discovery I
Old 11-26-2007, 06:20 AM   #13 (permalink)
taskforce121's Avatar
Smile
Hey Disco Mike (or others): where are the drain holes located? are they on the front edge of the sunroof? my son was getting dripped on this morning on the way to school, and the pass side headliner is damp. need some location info on these drainage holes. thanks as always.
phil
94 and 97 Disco I
We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm.
taskforce121 is offline   Reply With Quote
Old 11-26-2007, 06:59 AM   #14 (permalink)
HeadlinerExpress
HeadlinerExpress's Avatar
I can help answer any questions pertaining to Headliner & Sunroof Repair. This is our full time job; some of our Customers: Landrover Orlando-past 16 years – Florida Landrover club dot com - Merritt Island Landrover Jaguar.
Several issues related to water leaks on the Series I-II
Series I-II Sunroofs only have 2 forward Drain Tubes
All others Rangerover, Sports, Freelander etc.. Have 4 Drain Tubes
#1) We have found that in many cases the drain tube connection at the lower tub assemblies behind the Headliner Board breaks off due to heat and water showers in on the back of the headliner Board. This part is made of plastic and is factory installed only with black silicon.
#2) in some cases you can get by with replacing the Sunroof Seal between the Glass in the plastic Housing when you can see light looking from the inside out.
#3) We also have found that the medal roof is warped and the sunroof is unable to seat properly.Sometimes a body Shop is required to resolve this problem.
#4) debris between the Glass & the Seal
#5) but in most cases it’s really related to the Exterior Plastic Trim Ring, NOT THE Rubber seal between the Glass & the sunroof.
The Exterior Plastic Trim Ring with age warps’ from the heat and now you will find the glass is un-able to seat with the rubber seal and the actual sunroof because the Plastic Trim Ring is Twisted and the glass is not able to lay flush with the Roof.
In some cases you can remove the sunroof and install a used exterior plastic trim ring and get by, it some cases after spending endless hours and Money and quick fixes you will find only replacing the unit with a new Wabasto Sunroof will resolve your dilemma.
Let me know how I can help!
Headliner Express
Central Florida
68 Unimog TLF-8 Firetruck
65 Unimog Radio Box
www.HeadlinerExpress.com
HeadlinerExpress is offline   Reply With Quote
