Links
Old 08-31-2004, 01:09 AM   #1 (permalink)
Cam Williams's Avatar
Question Suspension kit?
Does anybody know if there is an on-road driving kit for the suspension for a Landy Disco 1? I have heard rumours of such a thing, and would really like to improve the handling of my 1997 County model. Any info is good info! Cheers.
Cam Williams is offline   Reply With Quote
Old 08-31-2004, 06:06 AM   #2 (permalink)
beer drinking member
dent's Avatar
what specificly are you looking for? to drop, lift, softer ride, harder ride etc
take care
sam
dent is offline   Reply With Quote
Old 08-31-2004, 04:05 PM   #3 (permalink)
Default shocks
Well the ride I have at the moment is pretty bad, as the shocks are a bit knackered. I guess that they are stock shocks and being 7 odd years old they are due to be changed anyway. I found a company in Germany (Bilstein) that make shocks that are apparently really good, and they come with a lifetime gaurantee. I am a little sceptical that any shocks could last that long!
Basically I am looking for a really good ride for on road use. I don't really use my landy for anything other than road trips and towing (awesome tow capacity!) So safe cornering and smooth would be the ideal.
Old 09-01-2004, 06:09 AM   #4 (permalink)
mankato's Avatar
I recently had all four springs replaced by a heavy duty set. This has certainly improved raod handling. Less roll on cornering.
John
mankato is offline   Reply With Quote
Old 09-01-2004, 09:34 AM   #5 (permalink)
I replaced alll the shocks for Gabrial and the bushings for Blue poly.
The ride is like Night and day. New truck.
sidawson is offline   Reply With Quote
Old 09-01-2004, 10:27 AM   #6 (permalink)
dent's Avatar
yes, those bilsteins are good, also you might want to check out some old man emu... depending on the tongue weight of what your towing might think about getting some heavy duty springs for the rear and something in the middle of the line for the front
take care
sam
Old 09-01-2004, 10:57 AM   #7 (permalink)
Series Moderator
onslow's Avatar
Thumbs up all of the above
If you do all the things suggested ie h/duty springs,polybush set(i use ironman arent they an aussie company),and bilstein shocks.it will be the motor you are looking for.
cheers ONz
Old 09-01-2004, 08:48 PM   #8 (permalink)
Thumbs up Thanks heaps you guys!
thank you all for the info, it sure makes a diference being able to get advise on this.
Cheers!
Cam
Old 09-01-2004, 11:23 PM   #9 (permalink)
Curt's Avatar
Lightbulb Check this out...
http://www.rocky-road.com/disco.html
the Med duty set would be a great choice for you in towing applications
Curt is offline   Reply With Quote
