Syptoms of bad torque converter? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 8 (permalink) Old 10-21-2008, 07:44 PM Thread Starter
TJ Nasty!
Jahmusac's Avatar
Quoted: 0 Post(s)
What kind of symtoms would i be experiencing if my torque converter is saying goodbye??
-Eractic shifting?
-only shifting when car is warmed up?
-not shifting into 4th?
-Or does this sound like new tranny time?
Jahmusac is offline
post #2 of 8 (permalink) Old 10-21-2008, 08:39 PM
roverich's Avatar
Quoted: 0 Post(s)
what dose the tranny fluid look like ? is it burnt looking ? or red color ? how many miles ?? off road much ? is it slipping ? is it low on fluid ? do you drive it hard ? do you let the car warm up, at all , before taking off ? it could be both things . i would check fluids first . then have trany looked at...... good luck.........
current vehicles : 96 Discovery-1 SE7. stock besides 255-70-r 16 ... SOLD
2000 Discovery-2 SD ...2 in OME 763 and 779 springs factory roof rail extensions , flat rack with 500ff's,hella 500's, .. new heads and head gasket . power steering pump , water pump . 265/75R16 guard dogs
roverich is offline
post #3 of 8 (permalink) Old 10-21-2008, 10:08 PM Thread Starter
TJ Nasty!
Jahmusac's Avatar
Quoted: 0 Post(s)
well it doesnt drive at all any more. it wont even shift into any gear. The tranny fluid looked the normal red color. i off roaded it time to time but nothing to hard on the car. i used to let it warm up before taking off but i live in the desert so thats not an issue i think. It has 180000 miles on it. i noticed the fluid level looked too high. i never filled it up before that. but i took it to some ghetto jiffy lube for an oil change(which ill never do again). then 15 min later the rover wouldnt go anywhere after sitting at a stop light. it just reved up in drive. i think they might have filled the tranny fluid too much without me telling them to. they told me theres a lot of leaks that i knew of already. but prior to that oil change that day my tranny was shifting in and out of differnt gears. now its been sitting for 9 months in my drive way so i got a 95 range classic in the meantime which i love. i replaced the trans fluid with some lucas trans fix and trans fluid then it almost shifted into reverse but no go(i heard the smack it usually made when shifting into reverse). i miss my disco.
Jahmusac is offline
post #4 of 8 (permalink) Old 10-21-2008, 10:19 PM
Ian Matthews
p76rangie's Avatar
Quoted: 18 Post(s)
Are sure it is not the transfer case. Try moving in low range. Also try difflock in and out
p76rangie is offline
post #5 of 8 (permalink) Old 10-21-2008, 11:40 PM Thread Starter
TJ Nasty!
Jahmusac's Avatar
Quoted: 0 Post(s)
the transfer case never shifted into low since i bought the car. it would go into diff lok though.There is fluid in the transfer case as well. the transfer case had alot of "smack!" when shifting into reverse i thought maybe the input or output splines were worn but that wouldnt make the car shift oddly like it did. would it? ill jump start it again tommorow and try diff lok with reverse and see what happens.
Thanks guys!
Jahmusac is offline
post #6 of 8 (permalink) Old 10-22-2008, 05:35 AM
Ian Matthews
p76rangie's Avatar
Quoted: 18 Post(s)
It is a bit late now that you do not have any drive, but the easiest way to test the torque convertor is to put in drive, put you foot hard on the brakes and try revving it up to around 2,000 rpm. If it starts to die/stall at 2,000 rpm, your torque convertor should be OK. Don't hold the revs there too long though as it can overheat the convertor.
post #7 of 8 (permalink) Old 10-22-2008, 08:16 PM
roverich's Avatar
Quoted: 0 Post(s)
its strange that it happened 15 minuets after you left a jiffy lube. I dont trust them, one time they put the wrong oil in my 96 d1 then swore he dident do it but he still had the oil nozzel in his hand.. i still go there but i stand right there and watch them do everything . just fluids i dont let them vacume or even clean the windows . i let them change a brake light bulb whene i first got my truck and they messed that up by not putting the housing bracket back on . whene i got hohe , the tail light was hanging out be the wires. i went back there and chewed them a new one. they HATE seeing me come in. hahahahahahaha
roverich is offline
post #8 of 8 (permalink) Old 01-03-2017, 01:11 AM
Quoted: 0 Post(s)
disco 1 torque converter replacement
I lost all gears while driving through a roundabout a few weeks back. Turned out something sheared off to do with were the torque converter goes into the pump at the front of the gearbox. This required a replacement converter . The car drives just as it did before but.... I noticed a vibration in the drivetrain that peaks at 1500 rpm that was there before the original failure, i'm wondering do any of you out there have any experience with this king of disco problem?
stpeter0 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Torque Converter Squeel???...1998 Range Rover 4.6 HSE Jigsaw89 Range Rover P38, Mk III and Range Rover Sport 11 06-03-2009 03:10 PM
HELP! Clanging noise! Torque Converter??? Paul 84 Range Rover Classic 1 09-10-2008 12:40 PM
Torque Converter Clutch Slip in 4th brian4d Discovery Series II 1 01-23-2008 06:18 AM
Isuzu Diesel conversion - new Torque Converter? adcomp Hybrid 0 12-13-2007 07:42 PM
I need a new catalytic converter CurvyRover Range Rover Classic 9 11-22-2006 09:20 AM
You may post new threads
You may post replies
