Old 09-24-2006, 09:20 AM   #1 (permalink)
Unhappy tailgate lock problem on 95 Disco
When I use the central locking system, the acuator does the right thing but there is no friction on the mecahnical part of the tailgate lock to keep in in either of the up of down positions. Result, I need to use the key.
The side doors have a definate "click" into position so I guess something has fallen off the mechanism.
Any ideas out there? I would be really appreciative ...
catseye is offline   Reply With Quote
Old 09-24-2006, 02:12 PM   #2 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
Mine does this too, I'm guessing it's some sort of engagement spring that's missing. I'm going to try to get the necessary pieces from Will Tillery this week, I'll let you know what fixes it.
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
Old 09-25-2006, 03:39 AM   #3 (permalink)
Thanks Felix,
I'll look forward to your findings. My guess was a spring but after much searching on the internet I found no useful information.
The entire tailgate seems to have more than enough problems - the subwoofer plastic moulding is badly damamged at most fixing points and the the speakers distort, so I guess the amp is bust, too. The wiper had stopped working and the jetwash was blocked. At the moment the wipers are working again and the wash will be fine when I have replaced the jet thingy ...
This all started by fixing the front-door window regulators and I thought "lets have a look at the back ..."
Next project - check the electrics to the rear door window regs which are firmly off (thankfully in the UP position!). Good job I have a toolkit!
C
Old 09-26-2006, 05:09 AM   #4 (permalink)
Default door lock repair springs for £3.75
there is a bloke on the uk e bay selling door lock repair springs for £3.75
not easy to fit but better than paying £60 for a new lock.
If he will not post to the us let me know as I bought 2 and only needed 1.
Sean
4x4disco is offline   Reply With Quote
Old 09-26-2006, 11:21 AM   #5 (permalink)
Thanks Felix - I'll check it out. I am based in the UK so postage should be OK.
C
