Links
Old 07-28-2005, 03:44 PM   #1 (permalink)
Question Temp Gauge question
I've noticed in my 99 Discovery I SD that if I've been driving for more than 30 minutes with the A/C on the temp gauge jumps from about 1/4 to 3/4, and I've also noticed a slight burning odor coming from under the hood. I'm just trying to figure out what that could mean, and how to fix it. I'm not very mechanical when it comes to cars, so any advice would be greatly appreciated. Thanks
AndrewBone is offline   Reply With Quote
Old 07-28-2005, 04:51 PM   #2 (permalink)
Black Magic's Avatar
In my case it seems to be a viscous fan coupling/fan clutch that is worn out.
Two choices on that
- replace the coupling/clutch (US$200 part)
- change over to electric fans (US$250 - $350
Black '02 Discover SII, Auto.
Black '87 Suzuki Samurai, rock crawler :
Black '94 Discovery SI V8i, 5 spd (Currently DOA)
--## If you have enough time to do something over again, you had enough time to do it right the first time. ##--
Black Magic is offline   Reply With Quote
Old 07-28-2005, 08:17 PM   #3 (permalink)
Thanks a lot for replying. I'll check out those options.
Old 07-28-2005, 08:57 PM   #4 (permalink)
Andrew,
Does this only occur with the AC on or all the time?
Could it also be the thermostat that's failed? Though seems to me that if it was, you'd heat up faster than 30 min... just throwing some other ideas out there...
'99 Disco I
'04 Disco II
Stephen99D1 is offline   Reply With Quote
Old 07-30-2005, 01:04 AM   #5 (permalink)
This only happens when the A/C is on. Also, I've noticed there is a substantial jolt when shifting gears...P to R, R to D, D to R, D to P. Is this something that I need to get checked out, or is it okay? I've been driving manual transmission for so long that this is completely beyond me. Most of this is beyond me anyways...I'm not very good with the mechanics of cars. I've also read that minor oil leaks are common on these cars, but can they be fixed easily? I want my parents to let me park in the driveway before it starts raining!! Thanks a lot
Old 07-30-2005, 05:39 AM   #6 (permalink)
Hi Andrew,
The Discovery has a very good cooling system so there is obviously something wrong. My guess is that the radiator is blocked and needs cleaning out,if it was the thermostat it would happen when your air con was off. The car is comming on 6 years old and if the previous owner didn't use corrosion inhibitor in the coolant the problems of a blocked radiator would be starting to happen. Cleaning the radiator out is not a huge job ,take it to a reputable radiator repair shop and get them to take off the top tank and rod out each of the cores(cost about$40US in Australia) then re-solder the top tank back on. Then get them to reverse flush the motor cooling sytem make sure you you a good coolant/inhibitor when you refill the system.
aussie disco97 is offline   Reply With Quote
Old 07-30-2005, 12:25 PM   #7 (permalink)
Thanks so much for that info. I'll do it first thing Monday morning. Any advice for the other problems? The jolt when shifting gears...the oil leak...anything will help at this point...Thanks again
