» Sponsors
» Sponsors
Old 10-11-2009, 04:43 PM   #1 (permalink)
the rig's Avatar
Gallery: 3
Default timing
can someone tell me when timing a 95 D1 do you use the diagram on the harmonic or do you use the notch in the harmonic??
the rig is offline   Reply With Quote
Old 10-11-2009, 07:37 PM   #2 (permalink)
Been there, Broke that
use the numbers and the tick marks where is says TDC
1991 RRC Great Divide Edition #245
Divied245 is offline   Reply With Quote
Old 10-12-2009, 08:09 PM   #3 (permalink)
the rig's Avatar
Gallery: 3
and should it be 5 deg. +- one deg btdc??
Timing Cover Reseal, Drive-shaft (reman), lift is this a reasonable quote? VRB Discovery Series II 2 07-20-2009 06:23 AM
D1 4.0 to Bosch 4.6 switch & timing covers JohnnyDisco Discovery Series I 2 06-09-2006 06:14 AM
Timing the 3.5 without the Timing Marks!! oldad Range Rover Classic 3 10-09-2005 08:39 PM
Timing Chain Breakage Jayce Series Land Rovers 14 08-18-2005 12:18 AM
Timing and Overheating mkerr2112 Defender 3 07-06-2005 03:57 PM
