Old 08-20-2008, 08:09 AM   #1 (permalink)
msggunny's Avatar
Gallery: 5
Default Towing package
Ok, so someone school me on what the Disco 1's towing package consists of.
I was under the impression that if a Disco had the towing receiver in the back that it would be "tow ready", apparently not. Unless i missed something.
I went to tow a trailer and "assumed" that there would be a wiring harness for the lights already installed, not so.
I know that in other SUV's they are tucked inside the truck somewhere, do the disco's have this?
Thanks.
77 SIII 88
97 D1 5 speed
91 D1 5 speed (the first, but gone )
the lord is my weapon
and i see him shoot pawns
woman is the devil
your god is a fraud
msggunny is offline   Reply With Quote
Old 08-20-2008, 02:44 PM   #2 (permalink)
antichrist's Avatar
Mine was there I think, but there is a plug tucked in behind the right taillight. It's a proprietary 7-pin round connector that another multi-conductor connects to that then runs out the bottom to the trailer connector. But you can, if you want, cut the end off the bundle of wires and run your own setup. You'll have to get one of the Eurpoean to Domestic light converters.
Here's how I did mine:
DiscoWeb Message Boards - View Single Post - 7 Pin Trailer wiring
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 08-20-2008, 02:55 PM   #3 (permalink)
2001 Disco 2
bd473374's Avatar
Gallery: 9
The Disco 1 should have a towing loom behind the right side rear light cluster. You should also be able to access this plug through a drop out plastic panel inside the vehicle partly hidden by the right hand rear seat (or storage bin in the case of a 5 seater). If you don't want to use a genuine set up, just cut the plug off and wire in directly, be careful of the purple thick wire as this has a permanent live 12volt feed.
This all assumes that NAS spec is the same as UK spec as far as wiring goes.
Looks like Antichrist got in first with the same advice, but this just confirms what I assumed.
bd473374 is offline   Reply With Quote
Towing Package for '95 Discovery? wgripp Discovery Series I 6 03-15-2008 06:45 PM
Positive Powerchip Experience and Towing Crysyn Discovery Series II 25 01-31-2008 10:46 PM
heated seats included in special package or a single option of the 05?? chris07 Discovery 3 / LR3 1 06-28-2007 05:23 AM
2004 Disco SE with Trail Package Upgrade jblieb Land Rover Vehicles 0 07-14-2006 08:02 AM
Towing with DII BrianP Discovery Series II 12 03-29-2006 08:01 AM
