Originally Posted by FOFFRACING
I have a 95 Disco that I am using to go trail riding. In these trails that are in NJ there is a lot of mud and water that I will have to go through. My question is to protect the distributor and coil in the front is there a grease or spray to cover the wires with? Also anything that you guys do already to prep your disco for mud and water.
Thanks
There is a lot you need to do if your going to go splashing around. Although these trucks are good offroad, they dont like too much water in the engine compartment or at all for that matter. You need to seal off your ECM/ECU(located pass side, rear engine compartment.) maybe get a snorkel and run breather lines up. get di-electric grease and put it on all the connectors. Much more should be done but if your just going to wade through water, you should be ok. if you're going balls to the wall, we will see you in more threads..... Good luck, have fun
