Links
Old 11-25-2007, 01:05 AM   #1 (permalink)
Question transferbox lockout trouble
I'm not getting power to the lockout solenoid on the transfer case on a 1995 disco. Is there some conditions that need to happen to activate the power? I know the trans needs to be in neutral, is there a neutral switch on the trans because I don't see a switch on the shifter. Any help would be great.
Ernest
kd6byo is offline   Reply With Quote
Old 12-04-2007, 10:30 PM   #2 (permalink)
Many many days later I found the trouble. Wire harness corrosion on a hidden terminating connector wrapped inside the harness directly under the junction of the AC unit and the blower. The circuit that feeds 12v to the key-in switch only had 5v even with the fuse for the circuit removed. Connected a tone generator and used a tracer to find the signal stopped midway in the harness. Invaluable tool this TestUm Tonax and ResiTracer has become. Looks like another few days till repair, as I will have to remove the blower to get full access to repair the harness wires. Will post pictures soon. Looks like the source of moisture is from a coolant leak, likely from the heater core as the dried up corrosion is baby blue colored.
Trouble Codes - Can someone Please decode? mortythebison Discovery Series I 5 03-13-2007 02:49 PM
Just got her, but having a little trouble IWANTADISCO Show it off 1 07-14-2006 08:32 AM
offroading trouble ryanc8514 Range Rover Classic 13 03-31-2006 02:58 PM
Trouble with starting TYLOUIE Discovery Series I 3 10-20-2005 01:29 PM
Landrovers financial trouble craigrmartin@silofx.com General Land Rover Discussion 4 04-16-2005 10:23 PM
