Old 01-30-2005, 06:16 PM   #1 (permalink)
Default Transmission cooling line??
Me again!!!!!! Notice a leaking line from radiator that I guess cools tranny?? I am not sure leaking on front pumpkin ?? Its a small steel line with a few rubber leads on it.. Was wondering if the rubber lines were added on or is it part of line and if not to tranny where does this line go?? Thanks\\
Eric
GentrysRover is offline   Reply With Quote
Old 01-30-2005, 06:38 PM   #2 (permalink)
Too much money,not enough sense
Default Yep thats a tranny cooler line...
rubber parts are stock...you'll wind up buying the whole assembly if its leaking from the rubber parts...otherwise you might just need the small crush washers that fit inbetween the cooler and the line or the tranny and the line...
Marcus
Quicksilva is offline   Reply With Quote
