Old 03-08-2007, 07:38 PM   #1 (permalink)
Default Transmission fluid change theories
I have heard that it is not good to change your transmission fluid on a high mileage vehicle if it has not been done in some time. My 98 has almost 125,000 on it. Since I bought it in 2000 never have I changed the transmission fluid. Bought it with almost 80,000 and no mx history. A bit brave, I know. SO, to change it or not to change it?
Disco Truck is offline   Reply With Quote
Old 03-08-2007, 08:00 PM   #2 (permalink)
Otherwise known as STEVE
If it is burnt, maybe just leave it and let it die a slow death. If the fluid isn't burnt and it was done before you owned it like it was supposed to be- then it's due and should be done.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 03-09-2007, 12:51 AM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
I can't see how changing the oil will do any harm. You should change the filter as well, which means dropping the pan, so you can give it a good clean.
Oil is cheaper than a rebuild.
Old 03-09-2007, 05:11 AM   #4 (permalink)
Elemental's Avatar
New ATF contains a fresh supply of detergents and
dispersants which can loosen the varnish and deposits
accumulated inside high-mileage, low-maintenance automatic
transmissions. On one hand, key components with tight
tolerances (such as solenoids and spool valves) may then be
exposed to the released debris. On the other hand, the
varnish and deposits may have been in a sort of
"equilibrium" in the automatic transmission. For example,
with the debris now removed from the frictional surface of
a clutch or band, the frictional properties have been
changed. Similarly, aged seals which may have had small
cracks once sealed by varnish and deposits may now be clean
and allowing internal hydraulic leaks.
Consider also that the seal swell additive in new ATF will
attempt to revive aged seals. And the friction modifiers in
the new ATF will try to provide the original level of
"slipperiness".
Again, the new ATF will simply be doing its designed job
which ends up revealing pre-existing problems in a
high-mileage, low-maintenance automatic transmission.
