| View Poll Results: After a Trans. fluid change, what were your results? | |||
| Positive - still running strong |
7 | 100.00% |
| Negative - please explain... |
0 | 0% |
| Voters: 7. You may not vote on this poll | |||
So, although I've asked questions and feel pretty confident about changing the fluid, I want that last bit of peace of mind.
Of the people who have changed their transmission fluid/filter or had it done by a dealer/mechanic, please vote above if you've had positive or negative results. Those with negative results, please post what they were. Thanks in advance.
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD Dsl - Wilks www.TerraTrekker.com
I'd just go ahead and do it. The filter will trap most of the crud that build up over time. As long as your seals are ok and not disintegrating you shouldn't have enough crud in there to worry about clogging your valves. If you really want to be safe you could always do 2 flushes, the idea being that the first will dislodge the crud, then it will be flushed out by the new fluid. Then just change it again and you'll be all set. I reccomend the method I posted in the other thread, it was super easy, just a little more involved than an engine oil change.
"A deep respect for tradition allows vision for liberation from stagnation." Colin's Toys: 1972 Series III 88" 1997 Discovery XD 1993 RRC (Gone to a better place, goodbye old friend) 1983 Stage 1 109" 2002 Trek 4500 2005 Necky Looksha Sport 2007 Rans Rocket 2007 Honda Ruckus |
Tom
I have mine done once a year regardless of mileage and have never experienced any negatives in doing so.
YMMV
Tom --2001 Disco II SE - sold --2004 Disco II SE - work and play truck --2006 LR3 SE - wife's truck (play when she's not looking)
Transmission fluid, when new is a excellent cleaner. It is chuck full of detergents.
Inside your transmission are paper gaskets, rubber seals, brake pad like friction material, and such. As a transmission ages, it goes through many hot and cold cycles from use and enviornment. The paper and rubber gets brittle inside the transmission. Used transmission fluid doesn't clean as well the same as when you wash dishes in a sink. The soap gets dirty and doesn't clean as well. The problem comes in when you indroduce new, fresh fluid. It cleans away the clutch material and, sometimes, the brittle gaskets and seals inside the transmission. This can cause internal hemroging(Sp?) causing the transmission fluid to go where it isnt needed. Automatic transmissions work on directing fluid, under pressure, to engage gears. Internal fluid leaks bleed off needed pressure and the transmission gives up. Now that you are scared, let me tell you the good. The ZF transmissions used in Land Rovers are some of the most stout transmissions I have seen. Usually, I see these types of failures in Domestic products, as they are build "Just good enough". Smart money is on changing you fluid often on any auto trans... Help keep the fluids detergetnts fresh. On a Discovery, i would have no problem flushing it.... They are hard core enough to take it.... And, if it kills the trans, frankly, it was on its last leg anyways. Good reading. http://www.mightyautoparts.com/pdf/articles/tt107.pdf
I only worry about myself, screw the others. |
Chris, thanks! Good post.
I'm doin in. Not this weekend, but the following, and I'll see if I can manage to make a photo documentary.
| Thread Tools | |
| Display Modes | |
| wheel cylinder rebuilding | theclay | Series Land Rovers | 23 | 05-21-2007 04:45 PM |
| Transmission fluid change theories | Disco Truck | Discovery Series I | 3 | 03-09-2007 05:11 AM |
| how to change transmission fluid in my RR2000 | gr8rangie | Range Rover P38, Mk III and Range Rover Sport | 2 | 03-09-2006 04:12 PM |
| 1999 4.6 needs some work; fix or sell? | Spring | Range Rover P38, Mk III and Range Rover Sport | 17 | 01-29-2006 01:18 PM |
| How to check auto transmission fluid on a 99' Series II? | RoverAsh | Discovery Series II | 1 | 11-02-2004 03:39 PM |
