Old 05-16-2008, 05:00 PM   #1 (permalink)
DErangeDrover's Avatar
Default transmission removal and replacement
Heres the deal. I am thinking about helping a friend replace the transmission in his 1996 land rover discovery. Does anyone know of an online shop manual for this vehicle? Or would the procedure be the same on a range rover classic? I have the shop manual for the range rover classic. If its the same i can use it. all help would be appreciated. thanks in advance.
deranged
DErangeDrover is offline   Reply With Quote
Old 05-16-2008, 05:35 PM   #2 (permalink)
The bellhousings are the same, there are four bolts that hold the torque convertor to the flex plate just like on the RRC, the frame mounts aren't very different, and the linkages are pretty straight forward (DI LT230 T/C vs. RRC BW). There may be an extra wire or two to disconnect but off the top of my head I can't imagine anything that would surprise you.
Paul Grant
paulgrant@mac.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Paul Grant is online now   Reply With Quote
Old 05-19-2008, 05:13 AM   #3 (permalink)
thanks Mr Grant for the info.
has anyone else done this procedure im sure someone has. also does anyone have a link to a free online shop manual. any direction would be helpful. thanks again
derangedrover
Transmission Replacement '99 D1 9dawgs Discovery Series I 4 04-24-2008 07:32 AM
Engine Removal / Replacement Sign Guy Range Rover Classic 13 11-04-2007 03:52 PM
Heater, coolant leak question for 2000 P38 Dburgoyne Range Rover P38, Mk III and Range Rover Sport 8 02-23-2007 01:47 PM
Replacing heater o-rings and servo gbvilla Range Rover P38, Mk III and Range Rover Sport 5 05-16-2006 06:59 PM
Oxygen Sensor replacement - 1991 Range Rover glenncof Range Rover Classic 1 08-04-2005 05:28 AM
