Has anyone installed the land rover genuine parts transmission service kit for the ZF4? I ordered one many months ago, but have been a little timid to take my transmission down and install the kit. Does anyone have any suggestions on how to do it? Rover's North says it is a pretty easy job. Are the rumors true that if the transmission has not been serviced in a long time it is better to leave it alone? I just don't want to open up another can of worms here. Any help is appreciated.
"A deep respect for tradition allows vision for liberation from stagnation." Colin's Toys: 1972 Series III 88" 1997 Discovery XD 1993 RRC (Gone to a better place, goodbye old friend) 1983 Stage 1 109" 2002 Trek 4500 2005 Necky Looksha Sport 2007 Rans Rocket 2007 Honda Ruckus |
#2 (permalink) | |
Do you mean the trans filter kit ? |
Yes, the one with the new filter and gaskets.
The hardest part about the job is removing the frame crossmember and dropping the exhaust y-pipe. The rest is cake! JohnC suggested using a hi-lift to spread the frame apart to help remove the crossmember.
#5 (permalink) | |
Sven is right the crossmember is a motherf***** to take out. First time i did mine i used a 2x4 and a big f****** hammer, once i got it out i used a disc grinder and smoothed down the both ends of the Xmem and frame rail and coated the surfaces with Permatex Anti Sieze paste. Saturate all the bolts with penetrant. Unplug O2 sensors. Drain trans fluid. Remove crossmember ? Unbolt swaybar and let swing down. ( D1 ) Remove exhaust Y pipe. Remove dipstick tube , the top bolt is a bitch to reach. Remove trans oil sump. Remove filter ,Orings etc. Good luck joe |
AAXD,
How many miles on your truck and how long has it bee since you last had it serviced?? For the most part, servicing a high mileage transmission after not being serviced for a long time can cause problems. The new fluids tend to strip to much varnish and laquer from the transmission and the next thing you know it is slipping or worse. If it has been a really long time since the last service, you might want to just pull of 2 or 3 qts. of old fluis and replace it with new. Mike J. |
#8 (permalink) | |
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD 2.25L Dsl - Wilks 1965 Series IIa 88' LHD 2.25L Petrol - Fionna |
