Trouble passing emissions and carbon only on one side of spark plugs? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 10-30-2016, 11:13 AM Thread Starter
Quoted: 0 Post(s)
My 1996 Land rover discovery failed it's smog test
HC GPS READING 1.5511 LIMIT 1.2000, CO GPM READING 21.5790 LIMIT 15.000, NOx GPM READING 4.8867 LIMIT 3.5000
I changed the air filter, plug wires spark plugs and ran high end fuel and injector cleaner through it but still runs about the same. (no problem starting up when cold but some times run low rpm at idle when hot. No smoke out the exhaust and drove it across the USA with no problems) Plug seem to have carbon only on one side. you can see spark photos
Any thoughts?
ID:	73185   Click image for larger version
gogol is offline
post #2 of 3 (permalink) Old 11-20-2016, 04:44 PM
Wounded Knee Moderator
ihscouts's Avatar
Quoted: 86 Post(s)
If your still around how many miles on the motor?
97 SD - Altai Silver. Sold
94 Saturn SC2
Roverless and wandering
The three-position Lucas switch--DIM, FLICKER and OFF.
The other three switch settings--SMOKE, SMOLDER and IGNITE.
Ultragauge
Contact info for Paul Grant;
203-770-1699
Contact info for Will Tillery;
540-462-7353
ihscouts is offline
post #3 of 3 (permalink) Old 11-20-2016, 05:13 PM
Special Agent
redtruck12's Avatar
Quoted: 112 Post(s)
Garage
From my experience as a certified repair technician with the Ontario Drive Clean Emissions testing program since 2000, I would tend to expect a failed catalyst in most cases where there is failure in HC, CO and NOX.
Does the vehicle set any fault codes?
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
MASSIVE carbon footprint!! Emissions failure ToddD Discovery Series I 21 04-11-2011 06:12 PM
Fouled Spark Plugs only on Passenger side?? 2001DiscoIowa Discovery Series II 1 08-20-2009 04:07 AM
Will the christmas trees prevent passing emissions? jommani2000 Discovery Series II 4 01-19-2007 02:00 PM
Spark Plugs & Spark Plug Wires 2002DiscoII Discovery Series II 13 05-14-2006 05:58 PM
Spark plugs imag Discovery Series II 27 11-13-2005 02:27 AM
You may post new threads
You may post replies
