Old 08-05-2005, 11:59 PM   #1 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
Question unknown cable
hello all! i just got a set of magnecor 8mm and had no problem installing the eight wires from the distributor to the spark plugs and the one from the coil to the distributor. when i looked in the box, there was one more cable. where does it go? see the attached image.
llesra is offline   Reply With Quote
Old 08-06-2005, 07:20 AM   #2 (permalink)
Elephantitis penisitis
You mean you only have 8 cylinders? Discos usually have 9 cylinders...
Probably a packaging mishap. Set it aside in case one of your wires goes bad.
Old 08-07-2005, 11:00 PM   #3 (permalink)
Gremlin's Avatar
That one should go from the dist to the coil, but if you already did that then its extra!
Grem
1974 Series 3 Tdi Power. The evolution of the series 3
Gremlin is offline   Reply With Quote
Old 08-08-2005, 02:04 AM   #4 (permalink)
Super Moderator
Disco's Avatar
Spare a thought for the poor bastard who only gets 7 leads in his order (assuming he ordered 8).
