» Sponsors
» Sponsors
Old 10-23-2009, 04:12 PM   #1 (permalink)
Default Vacuum. Is it On.
I know it should be on. 1994 Disco, no cats.
I need help. Because I do not believe my vacuum is functioning. I have a '94 D1 and I bought a can of seafoam to try and I am not getting anything off of the nipple on top the throttle body area... Maybe I just need a diagram but I can not figure this out. How can I check my vacuum...
vonbrandt is offline   Reply With Quote
Old 10-23-2009, 04:54 PM   #2 (permalink)
ihscouts's Avatar
Is the engine running when you try? Secondly the line might be blocked. Have your tried the vacuum line from the brake booster yet?
97 D1 SD
ihscouts is offline   Reply With Quote
Old 10-24-2009, 08:32 AM   #3 (permalink)
Super Moderator
If your engine runs, there has to be vacuum, as mentioned check all your hoses for leaks.
Also, if you hd nod no vacuum, your power brakes wouldn't work.
Old 10-26-2009, 02:26 PM   #4 (permalink)
Default I assumed the vacuum was a requirement.
I assumed that the vacuum must be working as the engine itself requires it, but I was trying to read up on the pcv. I feel really uneducated on this whole 'hook up a hose to the can of sea foam' deal right now. That is when I started up my car and pulled the hose coming vertically off of the plenum chamber upper... So does the engine need to warm up, should their be a vacuum off of this line on idle...
What is this !! ?? spiderfreak80 Discovery Series II 3 10-15-2009 11:25 AM
Revving - WHERE do those vacuum lines go? jennina1 Discovery Series I 1 10-10-2009 09:23 AM
Replace Vacuum Advance - 1990 RRC Irons1990County Range Rover Classic 2 07-29-2008 08:35 PM
Vacuum Advance scotgirl_an Discovery Series I 0 11-20-2006 03:59 AM
how do i take vacuum reading on p38? trademarks Range Rover P38, Mk III and Range Rover Sport 7 06-29-2006 12:42 PM
