Ello gu day mate ow r u?
anyone know how to adjust the valves after a head rebuild?
97 Disco1 128,000 Rebuilt heads up OME DEFENDER STEERING STABILIZER HD DRAG LINK RTE STABILIZER RELOCATION KIT PROCOMP HD +2 SHOCKS BB 2" LIFT SPRINGS 4" extended brakelines 4 stock Firestone Destination A/T Optima Red Top
just canceling out things to figure out y my engine won't start right. i guess its not the valves, its not the timing cause i don't have a distributor, and i got the battery tested its good. I guess i need to check the connections. i just don't know exactly which ones.
#4 (permalink) | |
You're in Springfeild....I'm in St Louis.
Perhaps a road trip is in order, a fresh set of eyes could help. Dont forget your basics. Gasoline engines need 5 things to run. 1)Air 2)Fuel 3)Spark 4)Compression 5)Timing. One, or more isn't there. Compression is a easy check witha comression gauge. Fuel, Pressure is easy, and a noid light will at least tell you if the injectors are being asked to turn on. Air....Make sure it can get IN your engine, but dont forget getting OUT. Spark is a easy one to confirm. Timing is set with your crank and cam sensor.... And, its uncheckable with a scan tool with live data stream. BUT dotn forget, if your timing chain isnt right, it cant do anything about it. Before I hunted down a timing concern, I would check the other 4 much easier, and more likely candidates. |
Ian Matthews
Did you change the lifters. They can be a pain to get oil back through them. When I replaced the cam and lifters I could not get them to prime properly with cold thick oil. Make sure that you prime the system by using an electric drill to the oil pump for 5 minutes or more.
As previously stated, you can get shims to reset the height, but this would usually only be needed if your seats have been recut low and your valves are also warn down. This can happen with a head job if things are pushed to the limits of servicability. |
#8 (permalink) | |
Well i wouldn't mind a fellow roverist looking at it. I have beer. i don't know what a noid light is. i got some new spark plugs to put in and i need to check the grounds. i'll try checking all that soon.
#9 (permalink) |
how exactly do u set the rocker gaps?
#10 (permalink) | |
http://www.handsontools.com/store-pr...hts_28675.html Heres what they look like, but they can be had at the zone for CHEAP, handful of dollars. I cant remember how far Springfeild is from STL, but I could come down maybe next weekend. THis weekend I'm heading to Ohio for a Fiat get together....(Yeah, I like wierd cars! ) |
