Old 04-11-2008, 09:01 AM   #1 (permalink)
daniels disco
Default volt/oil /temp gauges on a d-1
I am thinking of adding a 3 gauge set-up to my '94 disco (3.9l) My oil sending unit leaks and needs to be changed, my concern is the threading on the unit, is it a fine thread??? does anyone know the wrench size to remove the stock sending unit?? thanks, dan
daniels disco is offline   Reply With Quote
Old 04-11-2008, 09:20 PM   #2 (permalink)
AFIROVER
afirover's Avatar
what range are you thinking of useing ?
and you should ask PT SCHRAM if he knows the rest of the info you need just pm his ass
afirover is offline   Reply With Quote
Old 04-12-2008, 08:57 AM   #3 (permalink)
daniels disco
just the standard 3 gauge set up. oil press.- 0-80 psi, h2o- 130-280 , amps...
Old 04-12-2008, 04:08 PM   #4 (permalink)
AFIROVER
afirover's Avatar
you might look for a smaller range on the oil psi I have never seen a rover with more than 30ish psi
Old 04-14-2008, 01:31 PM   #5 (permalink)
daniels disco
well.., I am gonna bail on the idea.., seems all the gauges are set-up with a small oil supply line over the motor, thru the firewall and to the back of the gauge.., looks like a oil-based fire waiting to happen!!! run !!! thanks to all, dan
Old 04-15-2008, 06:53 AM   #6 (permalink)
AFIROVER
afirover's Avatar
you give up to ez
we are replacing all the gauges in ovis1 and adding more like fuel line psi and water psi and air fuel ratio all this in the truck in the center so both pass and driver can see and montor ...... just use an electric one
Stewart Warner Electric Oil Pressure Gauges - Ford Mustang
enjoy afi
After market gauges install question... atvsmurf Range Rover Classic 1 12-10-2007 06:59 PM
White Gauges For DI...Do they Exist? MightyMax Discovery Series I 2 04-21-2005 10:09 PM
