Old 07-25-2006, 05:49 PM   #1 (permalink)
Default Water drips
When driving and using the A/C at times I notice small drips of water exiting from under the console torwards the dash. It appears clear and doesn't smell of antifreeze. Any thoughts?
Tuco is offline   Reply With Quote
Old 07-25-2006, 06:21 PM   #2 (permalink)
All vehicles drip condinsation when running the a/c, it is when they don't drip that you have a problem.
Old 07-25-2006, 07:44 PM   #3 (permalink)
drewclare25's Avatar
yeah thats perfectly normal, check under any vehicle after its been running with ac, and you'll be reassured
Best 4x4xFar
97 Green D1
3" BB springs
pro comp es9000 shocks
32x11.50 BFG Mud Terrains
15" american racing steel wheels
flowmaster 40 series dual pipes
mantec snorkel
drewclare25 is offline   Reply With Quote
Old 07-31-2006, 04:59 AM   #4 (permalink)
Ray Wiley's Avatar
Hi,
I had the same problem and the garage cleared the air con drain hoses - one on each side, and that has stopped the water into the footwells. Once wet, the foorwells take an age to dry as the sound deadening and soundproofing is thick as!! And, it is a day's job to take the front carpet out as the seats and the centre console need to be removed.
I have taken the footwell side panels off and that has allowed me to lift the carpets and underlay, and prop up to dry out totally.
If it stays wet, you could be up for a new steel floor!!
Hope this is of some help
Regards
Ray
Ray Wiley is offline   Reply With Quote
