Water only in radiator? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 05-02-2013, 07:13 PM Thread Starter
Rover75's Avatar
Quoted: 0 Post(s)
I've heard just pure water is the best thing you can put in your radiator. Is there any truth in this? Where I live I would never have to worry about freezing. I'm getting ready to change out all hoses and flush radiator a bit. Thanx
MOLON LABE
"you cannot help men permanently by doing for them what they could and should do for themselves"
Abe Lincoln
2006 Range Rover Sport HSE 100,000miles (wife's)
2004 Discovery SE7, 190,000 miles
Mods coming soon!!
Wish List:
3" Terrafirma lift
Tactical Rover front and rear bumpers
Warn winch
Safari snorkel
Voyager rack (with tent modification)
1998 Discovery, sold but not forgotten
Rover75 is offline
post #2 of 6 (permalink) Old 05-02-2013, 08:30 PM
disco biscuit
disco biscuit's Avatar
Quoted: 0 Post(s)
Its a debatable subject I can tell you that much. To say its better to run straight water first requires distilled water. Prolly knew that. Anti-freeze is the proper term for what most people incorrectly refer to as coolant. Anti freeze actually disperses heat much less efficiently than water this is true. It also has a higher boiling point and lower freeze point. The higher boiling point, in some newer cars, is used to run higher temps with less worry. It works without it but just say it gets close to the 212 boiling point. The thermo in my powerstroke is 204. I dont recall the stock for my disco cause I got the 180° thermo, so i dont care. Point is it is accounted for some in engineering.
Also the mix of chemicals is much less subject to cavitation within the system and also rides on this system much slicker for lack of better explanation. It has more lubricity...lets say.
All that being said. Yes water does cool your engine much more efficently than straight water. Is it better...eehhhh idk. I try to stay close to 20% antifreeze 80% water in TX. But really dont pay much mind to it, I just dump a lil in and mostly add water. It might seem thoughtless but whatever. Beats doin a bunch of math for something that exact science isnt really that important as long as you dont use more than 50% anti freeze. It feels like a waste to have looked all that info up I just rambled when really, now, I could give a shit less. It shouldnt matter with a healthy coolant system.
disco biscuit is offline
post #3 of 6 (permalink) Old 05-03-2013, 03:54 AM
Administrator
Quoted: 5 Post(s)
Your engine will run hotter and in the case of our Disco's, the longer the engine stays hotter the greater chance you have of having the glue that holds your sleeves in fail and then you are into some big repairs.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #4 of 6 (permalink) Old 05-03-2013, 12:28 PM Thread Starter
Rover75's Avatar
Quoted: 0 Post(s)
Good info, so I guess I'll drop some antifreeze in there then, I'll just stick with the 50/50 or so. Thanx guys, that was good info. I'm with you disco biscuit, it seems like everything concerning fluids in general in these trucks is highly debatable, backed with a bunch of engineering specs and blah blah
MOLON LABE
Abe Lincoln
Mods coming soon!!
Wish List:
3" Terrafirma lift
Warn winch
Safari snorkel
Rover75 is offline
post #5 of 6 (permalink) Old 05-17-2013, 09:43 AM
Land Rover... Official off road Jeep recovery vehicle since 1948.
Quoted: 0 Post(s)
I just flushed mine out a few weeks ago when I replaced the water pump. I drained and filled it 4 times each time with the hose filling it to the top of the radiator then running the engine with the Heater full blast until the temp Guage started to climb, the last flush I did i used Prestone Antifreeze/Coolant - Choose your region | Prestone® radiator flush along with water, same process with running the vehicle, then emptied the cooling system the best i could of any cleaner or water left in the system and poured 1 gallon of premixed Dexcool, then I added a bottle of Lucas Super Coolant, then finished filling the radiator with premixed Dexcool until full. My trucks running noticeably cooler. I also removed the two auxiliary fans from the front of my radiator as they were fried and just blocking air flow. Bottom line I highly recommend adding Lucas Super Coolant It Does what it says.
Super Coolant : Lucas Oil
rockinryan96 is offline
post #6 of 6 (permalink) Old 05-17-2013, 12:43 PM
disco biscuit
Quoted: 0 Post(s)
I highly recommend dumping the dexcool out and using a more stable old school anti-freeze. That stuff turns into a terracotta mud sculpture the minute it makes any contact with air or combustion gases. Sometimes with no explainable cause.
ID:	37937   Click image for larger version
ID:	37945   Click image for larger version
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
New Radiator + Intake Manifold Gasket + Water Pump Gasket M Ford Discovery Series II 5 11-08-2012 10:19 AM
New radiator lambo Discovery Series I 5 07-16-2012 11:21 PM
Water Leak from Top of Radiator - Solution britishdesi Discovery Series II 10 12-26-2011 07:03 AM
Can water pump cause water to get into engine? rustycage12 General Land Rover Discussion 4 07-22-2010 02:08 PM
radiator MikeRaleighNC Discovery Series I 7 10-27-2008 05:21 PM
You may post new threads
You may post replies
