water pump grinding - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 12-12-2016, 05:42 AM Thread Starter
ark
99 Disco I
Quoted: 0 Post(s)
water pump grinding
99 Disco Series 1 water pump is making a grinding noise and it just so happened to start after I went to the car wash and sprayed some oil off the water pump and power steering hoses. The pulley connected to the fan blade is a little loose. I can tell the shaft is off center and loose.
My question is whether I can drive it 2 miles home or is it too risky?
Could the water pump shaft or fan seperate and cause more damage?
Can I drive it and just make sure the water temp doesn't get too high. I have already ordered a new water pump and plan to replace it as soon as I can get it home.
ark is offline
post #2 of 4 (permalink) Old 12-12-2016, 07:31 AM
Drives like an old man
discomania04's Avatar
Quoted: 31 Post(s)
Garage
Is it the water pump or the fan clutch? In either case, don't drive it till you fix it. You don't want to overheat.
2004 Disco II, bone stock, daily driver (gasp!)
discomania04 is offline
post #3 of 4 (permalink) Old 12-12-2016, 04:45 PM
Quoted: 23 Post(s)
If in the same fairly close range to home situation I'd consider removing the fan/clutch and drive it home. That would prevent the possibility of the fan causing damage. As long as the D1 is moving it shouldn't over heat sans the fan. I've driven my D2 sans the fan/clutch in 40 dgree weather and never overheated. Still a slight risk the pump could grenade and some damage. No guts no glory or leave/tow.
2004 NAS Discovery SE - DD/Owner/Maintainer
number9 is offline
post #4 of 4 (permalink) Old 12-16-2016, 06:24 PM Thread Starter
ark
99 Disco I
Quoted: 0 Post(s)
It was the water pump. I could see some aluminum metal shavings just behind the shaft.
Thanks, I got it home and when I pulled the old water pump offl it was showing some scrap marks from the propeller off center.
ark is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Water pump jdoeren Discovery Series II 5 01-20-2013 09:40 AM
Can water pump cause water to get into engine? rustycage12 General Land Rover Discussion 4 07-22-2010 02:08 PM
New water pump $59 MojaveMike45 Discovery Series II 2 10-06-2009 02:49 PM
water pump redrover98 Discovery Series I 17 04-26-2009 09:19 AM
water pump moreheads Discovery Series I 2 07-22-2007 06:22 AM
You may post new threads
You may post replies
