Weird Disco Overheating after Head Gasket Job
My son bought a '97 Discovery with blown head gaskets. We pulled the heads, installed new OEM head gaskets and intakes, reassembled. Heads were decked, new head bolts properly torqued. Car was assembled with coolant and copper Bar's Leak to stop any pinhole leaks.
Once assembled, car started first try. It ran 20 minutes with just a small amount of steam, but no water seemed to be lost in radiator. After that, it stopped steaming, ran just fine. He drove it about two miles, then suddenly the engine speed increased and then it overheated and blew out about a third of the coolant. We allowed it to cool overnight, refilled the coolant and let it burp. Ran fine at idle, then suddenly, the engine speed increased and coolant again burped out.
If the engine is revved up it runs pretty good, then kinda makes some loud bangs - either in the exhaust or perhaps its a loud knock.
My thought is that the engine is either suddenly going very lean or that timing is somehow advancing. Or maybe we missed something, or its just a bad omen of things to come. Maybe its just full of crud - the prior owner apparently ran it without therostat and with only water for a long time. There is LOTS of deferred maintenance on this car.
Oh - and it shimmy's in the front end! 'Natch!
Any thoughts?
How is the fuel/air mixture actually controlled in the fuel injection?
And where is the sensor that triggers the spark? Maybe it's loose?
Thanks!
Tom
