Old 09-16-2007, 10:22 PM   #1 (permalink)
Default Went to dealer, had codes read. Here they are!!!
everything has been fixed thanks guys
bigd2010 is offline   Reply With Quote
Old 09-17-2007, 05:44 AM   #2 (permalink)
Elemental's Avatar
What year is your truck?
Old 09-17-2007, 06:25 AM   #3 (permalink)
I am going to let Elemental reply to your questions but wanted to make one suggestion. Order 8 mm Magnacor wires instead of the Bosch, they sem to do really well on Rovers.
Old 09-17-2007, 06:33 AM   #4 (permalink)
Elemental's Avatar
I agree with Mike on that. Bosch wires often bought at the Zone are shit. Not as bad as the red zone house brand, but close.
Magnacore all the way.
Old 09-17-2007, 08:51 PM   #5 (permalink)
it is a 1996 discovery 1 with 94k miles.
Old 09-17-2007, 08:51 PM   #6 (permalink)
already bought the bosch ..plus they were only 33 bucks haha
Old 09-18-2007, 03:56 AM   #7 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
For your overheating issues, might be your viscous coupling is worn out on the fan.
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Old 09-18-2007, 06:10 AM   #8 (permalink)
Elemental's Avatar
I was hoping you wouldnt say that.
First, the p0125 is Either your Thermostat...Or, there is a Updated PROM to address this concern. Turns out, it is discontinued.
96 had many p0300 codes set by sticking valves. If they havent been updated with the carbon cutters then all the spark plugs in the world will not help. Somethign to keep in mind. In 96, when we had a p0300 we would install new plugs and wires and give it back to the customer explaining that we need to see it again, and give them a free Oil Change for there time. If it came back with the same code... New valves.
Hey, it was under warranty.
Does your check engine light blink at the rate of 1 blink per second when its acting up?
Old 09-18-2007, 10:11 AM   #9 (permalink)
truck is perfect running order
Old 09-18-2007, 11:23 AM   #10 (permalink)
Elemental's Avatar
Start with plugs and wires... See what happens.
Old 09-18-2007, 06:36 PM   #11 (permalink)
got champion plugs(the better ones they sell)....bosch wires are on the way...if they fail ill for over the 110$ for magnecor
