anybody help on poss causes of water getting into drivers footwell? i have a very squishy carpet on the righthand side of the drivers footwell close to where the door shuts to thanks
#3 (permalink) | |
i would check the sunroof drain tubes they r difficult to get to but can get clogged with leaves. if you pull the a pillar trim you can see the drain tubes or you can open the roof and do a visual inspection and blow air through the lines
#5 (permalink) | |
Is The Car LHD or RHD?
On RHD cars there is a wiring loom that goes through the bulkhead behind the screen washer bottle.The grommet the loom passes through isn't always watertight and can allow water to run down the inside of the bulkhead to soak the carpet. |
#9 (permalink) |
This will sound stupid, but I had this problem a few times. You know what it was? The thick, plush carpeted floor mats that I use daily had slid just far enough towards the door that it stuck a little bit into the door jam. It was raining outside, and it sucked up so much water that my whole floor board was soaked. This has happened twice (my wife drives my Disco, too, so it's her fault
) so you should check it.IF this is it, don't feel bad. Remember, it happened to me too (twice). |
#10 (permalink) |
I took mine to the dealer due to a leak in the front passenger side floorboard. Listed on my invoice said the cause was "cause K25
822500 Evaporator unit. Evap drain plugged. .2 hours AC evap drains plugged. Clear drains Cost $19.20. It doesn't leak anymore. |
