What does this button do? ( TDi 1997 discovery?) - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-27-2012, 01:10 PM   #1 (permalink)
Ridgeline Adventures
Default What does this button do? ( TDi 1997 discovery?)
Hi folks
Not sure if my tdi 1997 has air con or not. It has this snowflake button (see image - middle switch). When I push it no light comes on and it doesnt blow cold air. The fan does work so expected cooler air to come if I push this snowflake button but no change. If it is A/C it is not working so also advice on getting to to go would be great. If it's not A/C button can someone identify what it is please?
Thanks in advance
What does this button do? ( TDi 1997 discovery?)-2012-11-28_09-11-01_237.jpg
morbell is offline   Reply With Quote
Old 11-27-2012, 01:22 PM   #2 (permalink)
It's your A/C. If its not blowing cold.... See if the compressor is engaging at all when you push it. If not, it could be a variety of things. The easiest to check would be the the freon level. You can get a gauge at any parts store. If the compressor does engage, you're probably just low.
So I guess it looks you'll need a gauge in either case. It has to be reasonably warm for the system to work. What's the temp outside when you tried it?
Sold my 2000 Disco and just picked up a 1995 D1 beater. Sometimes I make poor choices.
stb616 is offline   Reply With Quote
Old 11-27-2012, 03:04 PM   #3 (permalink)
Temp is about 24 celcius - maybe 70 or so,pretty sure its hot enough outside. So how and where do I look to check freon level?
Old 11-27-2012, 04:08 PM   #4 (permalink)
Watch that video, guys kinda a shmuck, but it goes over the basics of the system. Needless to say don't stick your hands in there while the engine is running.
If you go to a parts store to buy a gauge, they should be able help you with where to hook it up.
FYI- If the system is completely empty, it's beyond what you can fix yourself.
Old 11-27-2012, 05:53 PM   #5 (permalink)
Spike555's Avatar
My a/c button does not light up but it works fine, been that way as long as I've owned it.
With the engine running press the a/c button, do the electric fans behind the grill come on?
There are two, they both should come on, if not it might be a...wait for it...blown fuse.
If the a/c is so low the compressor will not kick on you need a shop to trick the compressor so they can fill the system.
I was taught a trick to fixing leaking a/c lines, where the metal line crimps to the rubber line you can clamp the collar with a really good hose clamp, that will stop the leak.
That is the most common place for a/c leaks on older cars.
The a/c on the DI will run no matter the outside temp, I've ran mine at 0*F to defog my windows in the winter from breathing to heavy after sledding.
2nd owner of a '97 Disco with a ARB winch bumper, SD roof rack, Rover Racks ladder, Cooper S/T's and 220,000 miles on the clock and still a daily driver.
Spike555 is offline   Reply With Quote
Old 11-27-2012, 11:07 PM   #6 (permalink)
yes both fans come on, just no cold air. So next step is to get a shop to refill the system correct? Is this a big/costly job?
Old 11-28-2012, 07:08 PM   #7 (permalink)
Spike555's Avatar
Is it a big job? No.
Is it costly? Depends on how much R-134a they need to add.
You can buy a DIY a/c re-charge kit at the parts store and try that first, you can get one of those for around 20USD.
Old 11-29-2012, 10:19 AM   #8 (permalink)
cheers. good to know.
TDI 1997 ES - Fuse for rear sunroof blowing morbell Discovery Series I 8 11-28-2012 01:12 AM
1997 Discovery XD Tdi collin380 Land Rover Vehicles 4 07-10-2012 06:11 PM
1997 discovery tdi tasdiscovery Show it off 0 05-31-2010 03:30 AM
1997 Defender 110 TDI LHD what's it worth? bikedown Defender 2 08-28-2007 07:02 AM
Defender 300 Tdi Steering play 1997 wamccutcheon Defender 3 06-19-2006 06:48 AM
SEO by vBSEO 3.3.2
