Old 07-18-2006, 04:55 PM   #1 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Default What fuel conditioners...
Ok just wanting to get a list of products that are made to take the moisture out of the fuel system. I have used both Heet and STP fuel conditioner with good results. What else is out there?
Old 07-18-2006, 05:15 PM   #2 (permalink)
Heet is probably the best, but why are you getting that much water in your tank?
Old 07-18-2006, 05:33 PM   #3 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Not quite sure why. Need to poke around a little. Can't see that sitting in the water and mud for an hour would have done much although the gas tank would have been 90% submerged. The only thing I can think of is that I spent quite a bit of time with the power washer around the gas tank spraying off the muck. Of course I did also fill up at a po- dunk gas station in the middle of no where so maybe they had bad gas. All I know is that everything I did with my truck seemed to progressively help out my problem. New-used MAF sensor, new OEM plugs, new fuel filter, still got codes but ran better still stumbled and had codes... put fuel conditioner, good to go!
Old 07-18-2006, 05:49 PM   #4 (permalink)
Ian Matthews
p76rangie's Avatar
First off, there should be a drain plug on the tank. Any water will be at the bottom and come out first.
The best and cheapest way to get rid of the water is to add some methylated spirits into the tank.
Ian
Old 07-18-2006, 06:07 PM   #5 (permalink)
There are no fuel tank drain plugs in US production Rovers.
What won't just leak in while doing a water crossing or being washed, these tanks are presurized while being driven and if there were an opening you would have a code.
Old 07-19-2006, 03:41 AM   #6 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Then the gas is suspect. Oh well knock on wood my truck running decent right now.
