Old 06-16-2007, 09:38 PM   #1 (permalink)
The Badge of Honour (MUD)
Dirt Diva's Avatar
Location: Calgary ,Alberta not alot of Off roading here..booo
Red face What Now!!
Hey all, Ever since i got my Pretty Baby (Lizzy) she has had, Electrical issues re, The passenger door is now a dummy lock it wont open from the outside and when i open it form the inside i have to pull the doorlock and then the handle at the same time.
2)The alarm has a mind of it's own, she will go off for no reason, like if the key has not turned the proper way she goes off (wierd)
3)The Rear hatch leaks from the top
4) the Cruise controll cuts out after ahwile.
5) the rear windows finally started working after a month
OMG I LOVE HER BUT THESE ARE STUPID LITTLE THINGS, help HELP!!
Get er Done!!!!
Dirt Diva is offline   Reply With Quote
Old 06-16-2007, 10:30 PM   #2 (permalink)
Dirt Diva's Avatar
Ok this is Dirt Diva and Lizzy ..today i logged on to this site and today my Ignition cylinder went i cant turn my key at all.. i think me got a lem.
Get er Done!!!!
Old 06-17-2007, 09:24 AM   #3 (permalink)
pavel's Avatar
Many of your problems may well result from condensation and general moisture in dozens of electrical connections - I note that you live in a wet area (we live in an even wetter area). Frankly, you will probably always have trouble with locks, window mechanisms, alarms etc. One way to attack, maybe improve the situation is to systematically open & clean (with contact cleaner) every electrical plug you can find. This is tedious and unrewarding work because 95% of the time the electrical connection is fine.
Permit me to suggest that you keep 'Lizzy' for fun and use a Japanese appliance vehicle for everyday use. This approach will save you money and keep your blood pressure down.
Visit my j**p website
Old 06-17-2007, 10:13 AM   #4 (permalink)
96owner's Avatar
dont know howto help you try to clean up all the connections
replac all the weather seals i just did and it stoped. but then pull your carpet and let it dry out and there is probly rust back there.
unless you use it a lot give up on fixing it i did after a year
mine just stoped haha
Delaware Mother******!
1996 Disco
Myspace
mods:
OME HD lift (thaks max)
zombie
96owner is offline   Reply With Quote
