Hey guys, as you probobly know(or don't), I purchased my 95 Disco I this summer. It is lifted 2"(or 3" I'm not sure) and is running 33" Interco trxXus tires. I havn't really had any major maintenance, just repairs(go figure? lol). I'm up in the mountains so I'm going to have the oil changed for the arriving cold weather, as well as fluids changed/topped off. I want to have them grease my drivetrains and suspension also, because I'm hearing a grinding/grumbling noise when I let off the gas as speeds usually under 10-15 mph. I was wondering what else, realativly inexpensive, should I have done to my baby? Please list the brands and types of fluids/oils you reccomend, as I'll take note of them when I bring her in. Also, my leather seats are tearing a tad in the front. I've applied leather conditioner to them to maintain the good parts of it, but what options do I have in this area? They're not across any segments, they're isolated. I appreciate all you're input and hope to get some new pics of her up(I know, I'm not the quickest with pics lol).
Thank You, AppStateDisco
AHO Rugby, a drinking club with a rugby problem. www.ahorugby.net "My experience through life has convinced me that, while moderation and temperance in all things are commendable and beneficial, abstinence from spirituous liquors is the best safeguard of morals and health." - Robert E. Lee |
bump
7,500 MILE SERVICE
Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Under Vehicle *Change engine oil and replace filter Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Inspect trailer hitch attachment bolts for tightness Change front and rear axle oil Record performance of Service in Passport to Service 15,000 MILE SERVICE Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Lubricate door locks, check straps Lubricate hood latch and safety catch, fuel door hinges Interior Check parking brake (Adjust if necessary) Check seat belts Under Hood Inspect coolant hoses Inspect radiator and AC condenser Check power steering fluid level/ACE fluid level Clean battery and terminals Inspect serpentine drive belt Check brake fluid level Under Vehicle *Change engine oil and replace filter Perform body corrosion warranty inspection Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Inspect exhaust system and heat shields Inspect brake lines Lubricate drive shafts and U-joints Inspect steering rods, joints and dust covers Inspect shock absorbers Inspect suspension links and mountings Inspect wheel speed sensor and height sensor wiring Inspect fuel and hydraulic lines Record performance of Service in Passport to Service 22,500 MILE SERVICE Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Under Vehicle *Change engine oil and replace filter Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Record performance of Service in Passport to Service 30,000 MILE SERVICE Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Lubricate door locks, check straps Lubricate hood latch and safety catch, fuel door hinges Replace Alarm handset batteries Interior Check parking brake (Adjust if necessary) Check seat belts Under Hood Inspect coolant hoses Inspect radiator and AC condenser Check power steering fluid level/ACE fluid level Clean battery and terminals Inspect serpentine drive belt Change brake fluid *Replace air-cleaner element Change engine coolant Under Vehicle *Change engine oil and replace filter Perform body corrosion warranty inspection Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Inspect exhaust system and heat shields Inspect brake lines Lubricate drive shafts and U-joints Inspect steering rods, joints and dust covers Inspect shock absorbers Inspect suspension links and mountings Inspect trailer hitch attachment bolts for tightness Inspect wheel speed sensor and height sensor wiring Inspect fuel and hydraulic lines Change transfer gearbox oil Change transmission fluid Replace transmission fluid filter Check front and rear axle oil level Record performance of Service in Passport to Service 37,500 MILE SERVICE Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Under Vehicle *Change engine oil and replace filter Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Record performance of Service in Passport to Service 45,000 MILE SERVICE Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Lubricate door locks, check straps Lubricate hood latch and safety catch, fuel door hinges Interior Check parking brake (Adjust if necessary) Check seat belts Under Hood Inspect coolant hoses Inspect radiator and AC condenser Check power steering fluid level/ACE fluid level Clean battery and terminals Replace serpentine drive belt Check brake fluid level Under Vehicle *Change engine oil and replace filter Perform body corrosion warranty inspection Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Inspect exhaust system and heat shields Inspect brake lines Lubricate drive shafts and U-joints Inspect steering rods, joints and dust covers Inspect shock absorbers Inspect suspension links and mountings Inspect wheel speed sensor and height sensor wiring Inspect fuel and hydraulic lines Inspect engine and transmission mounts Record performance of Service in Passport to Service 52,500 MILE SERVICE Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Under Vehicle *Change engine oil and replace filter Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Record performance of Service in Passport to Service 60,000 MILE SERVICE Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Lubricate door locks, check straps Lubricate hood latch and safety catch, fuel door hinges Replace Alarm handset batteries Interior Check parking brake (Adjust if necessary) Check seat belts Under Hood Inspect coolant hoses Inspect radiator and AC condenser Check power steering fluid level/ACE fluid level Clean battery and terminals Inspect serpentine drive belt Change brake fluid *Replace air-cleaner element Change engine coolant *Replace spark plugs Under Vehicle *Change engine oil and replace filter Perform body corrosion warranty inspection Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Inspect exhaust system and heat shields Inspect brake lines Lubricate drive shafts and U-joints Inspect steering rods, joints and dust covers Inspect shock absorbers Inspect suspension links and mountings Inspect trailer hitch attachment bolts for tightness Inspect wheel speed sensor and height sensor wiring Inspect fuel and hydraulic lines Change transfer gearbox oil Change transmission fluid Check front and rear axle oil level Service SLS filter (if equipped) Record performance of Service in Passport to Service back to top * Required emission maintenance |
| Thread Tools | |
| Display Modes | |
