Speakin of the friggin devil... (reffering to the the Oil Filter Query thread )
So I'm preparing to change my oil this morning, and while I'm gettin the tools from the shop, my dad wanted to test this new set of socket wrenches he got and drained my oil first. I later proceed to change the oil oil filter AFTER the new oil had been put in. So I do that, turn the car on, and it runs like crap! Took a 200 mile trip today and the whole time I was thinkin "it'll go away now".....10 miles later....."I'll go away now!" It didnt go away. Besides the vibrations I get from my damaged RotoFlex, my engine was all jumpy...almost as if the spark plugs were about to be goners, (which I'm changing tomorrow). What are the chances that the moment after I changed my oil my spark plugs decide to give up on me? Or what else could be the cause of the jumpiness, besides the fact my normal procedure for changing oil was changed? I'm thinkin its definately spark plugs. When I step on it, it lags like a mofo and shakes. At one of the rest stops, I left the truck running and stepped out and heard random sputtering from the tail pipe but my engine sounds fine. I'm all ears guys! Thanks! JC ![]()
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD 2.25L Dsl - Wilks 1965 Series IIa 88' LHD 2.25L Petrol - Fionna |
#3 (permalink) | |
Elephantitis penisitis
Perhaps a vacuum leak.
#4 (permalink) | |
You know, you also bring up another point, could I have put too much Oil in it? I put 6qts. But this morning was chilly so could there have been old oil that was thicker and accumulated somewhere that didnt drain? I'll check again for oil appearance inthe morning, since it's still hot now.
#7 (permalink) | |
#9 (permalink) | |
#11 (permalink) |
For as bad as it is running, do you have a check engine light??
A quart of oil one way or the other will not cause it to run bad. What brand of oil filter did you use, does it have the proper pressure relief spring? I have to think it is some other unrelated problem. How many miles on your truck? Mike J. |
#12 (permalink) | |
I do have the CE light. But its from the bad O2 sensors as well. My truck has 128k. The Filter I used was a KN P/N: HP-2004. Been using those on all of my cars. I checked the oil before I came to work and it was fine. Not foamy, looks good, and level is ok.
#13 (permalink) | |
Have you checked the codes since this has happened to see if you picked up another code? Mike J. |
#14 (permalink) |
Guys, while changing the plugs today, when I came across plug #3, I had barely put my hand on the boot when all of a sudden the wire falls out of the boot and I discover the culprit. I dont know how the wire didnt fall out with all the vibrations...it was hanging on there by what could be called a rubber thread! Keep in mind I did a 200+ mile trip! This thing was running on 7 Cyl. What a friggin truck!!!
#15 (permalink) |
Glad to know you are back on the road full bore JC.
