Old 07-12-2006, 01:03 AM   #1 (permalink)
Majesticdisco1
disco12's Avatar
Default What's the best gear oil for me to use
Now that I have a repair manual I'm gonna do my own axle and T-case oil changes. My T-case leaks a little so I'm gonna refill the box back up and I'm doing my own axles. I know the key to rovers is to keep them "fresh" oiled and "wet". I'm finally getting into the DIY mode. ? is whats a good gear oil to use for both. For smooth running and operation. My disco is my DD now so I have to make sure I keep her insides fresh and "wet"
Thanks D12 (Jarell)
1996 D1
RTE 3"
33" BFG MUDS
Old 07-12-2006, 01:11 AM   #2 (permalink)
RageRover's Avatar
Well, the T-case is gonna take a couple quarts of plain ATF is all it needs, so no gear oil needed for the T-case.
For the diff fluid/axle fluid, use the weight recommended of course, but for a particular brand, my friend uses Lucas 80/90 gear oil in his, and has not had a problem at all. He used the synthetic gear oil on 84 Chevy Silverado 4x4. I myself am probably also going to use Lucas when I change the dif fluids on mine.
As for brand of ATF, any brand is good, just to throw it out there, Valvoline makes some good stuff.
Hope this helps a bit man!
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 07-12-2006, 03:58 AM   #3 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Whoa, WHOA on the auto transmission fluid in the transfer case!!!!!!!!!
The transfer case uses GEAR OIL NOT ATF!!!!
I have always used 80/90weight Lucas gear oil in both front and rear diffs, and in the transfer case. To make the transfer case job alot easier get yourself a fluid transfer pump from your local auto parts shop( they are anywhere from $10-$15) as it is impossible to get a bottle of GEAR oil to the filler hole without it. Only use ATF in obviously an auto trans. and the power steering system!
Old 07-12-2006, 06:23 AM   #4 (permalink)
X2
Also if you want one of the best gear oils out there, and I am a big promoter of Lucas also, try some of this gear oil from Superior Axle down in Riverside, Ca.
You can find it in some performance shop or order on line. I have been using it ,going on 4 years, because I run a Detro and a T.T.. Detroits can be a little noisey and this oil keeps them running very smoothly. By the way, I also run this in my t/case to help off set the heavy amount of CDL wheeling I do.
The big plus for this oil is that most gear oils are rated as a GL4, good oils are GL5 and this stuff is a GL6. Try finding a bottle with that sort of rating in your favorite auto parts store.
Good luck with what ever you buy
Old 07-12-2006, 09:09 AM   #5 (permalink)
RageRover's suggestion of ATF in your transfer case stems from the fact that he has a Borg Warner unit in his Range Rover. Your Discovery has an LT230, does not have a viscous coupled center diff and therefore uses gear oil. Land Rover recommends 80/90 weight gear oil.
Old 07-12-2006, 11:14 AM   #6 (permalink)
The bloke I just bought a recon. diff from says use only EP90.
Bonehead is offline   Reply With Quote
Old 07-12-2006, 11:29 AM   #7 (permalink)
I hear what you were told, I am just offering some feedback from one of the largest makers of diffs and axles in the U.S. which says they have some strong experience with diffs.
Old 07-13-2006, 09:17 PM   #8 (permalink)
texasrover's Avatar
80/90 Amsoil Gear Oil.
Oh hell if Amsoil makes it I run it... who am I kidding. I am not even a dealer. haha
My office is about one mile from the pick up warehouse in Arlington, Texas. I order before I leave the office and stop by on the way home and get it. Like stopping at Sonic for a couple of Jr Burgers and a Orange Cream Slush.
That is not a leak! That is undercarriage rust inhibitor.
98 Discovery
Old 07-13-2006, 09:18 PM   #9 (permalink)
texasrover's Avatar
LUCUS is great stuff too
98 Discovery
Old 07-13-2006, 09:33 PM   #10 (permalink)
Proud to be an Infidel
FlyWheel's Avatar
Ditto on the Amsoil.................
2001 Disco SE7
.......eventually they will run out of suicide bombers.....
FlyWheel is offline   Reply With Quote
Old 07-14-2006, 11:12 AM   #11 (permalink)
AFIROVER
afirover's Avatar
diff = 90wht with lucas
thats what we run in ovis1
afirover is offline   Reply With Quote
Old 07-14-2006, 09:13 PM   #12 (permalink)
RageRover's Avatar
Jesus, I am stupid.
1995 RRC LWB
Old 07-15-2006, 04:07 AM   #13 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Originally Posted by RageRover
Jesus, I am stupid.
Nah.
