» Sponsors
» Sponsors
Old 10-29-2009, 06:06 PM   #1 (permalink)
Default Where can I find the propshaft socket adapter...
I am trying to remove my rear drive shaft again and would like to make it easier on myself. I am in Atlanta, Ga. USA and have only found this tool across the Atlantic... advice/thoughts on where to get this tool a bit closer...
vonbrandt is offline   Reply With Quote
Old 10-29-2009, 06:09 PM   #2 (permalink)
A conclusion is the place where you got tired of thinking
Ultraviolet's Avatar
Gallery: 3
is your mail box close enough for you
Driveshaft Socket Wrench Tool - 9/16" Nut - 3/8" Square Drive for Range Rover Classic | Land Rover wheels, tires, hubs, axles
I am the White Rabbit
Ultraviolet is online now   Reply With Quote
Old 10-30-2009, 08:46 AM   #3 (permalink)
I can't even hazard a guess at how many prop shafts I've taken off over the years but I have never found there to be a need for a special tool. I always start at the diff end (front or rear) of the shaft with a pair of 9/16th wrenches, one boxed, one open. Apply a little heat and the nuts and bolts come off. At the brake drum, I just move the shaft from side to side to enable access with a 9/16th socket, hook up my impact and the four nuts are off in seconds. It never takes more than a few minutes and the shaft is off.
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 22 11-10-2009 05:47 PM
ARB on board compressor adapter cheekoman Discovery Series II 4 05-04-2009 07:07 AM
Front PropShaft on Range Rover 4.6 HSE P38 acetech Range Rover P38, Mk III and Range Rover Sport 2 04-28-2009 04:11 AM
trailer light receptacle adapter sine mora Discovery Series II 5 05-23-2008 06:17 PM
front propshaft mairiain Discovery Series I 0 03-02-2005 07:57 AM
SEO by vBSEO 3.3.2
