» Sponsors
» Sponsors
Old 10-31-2009, 12:24 PM   #1 (permalink)
Default Window Lift ECU Problem
It's the "window lift ECU for our '95 Disco I" story, coming back to haunt this forum on Halloween.
Initially (long story here), the rear windows wouldn't roll down *from time to time*. No big deal there, right? Then, mysteriously, the front windows stopped working. After reading some posts on here, I replaced the ECU (after trying, unsuccessfully, to re-solder it). This allowed the front windows to roll down, but then the rear windows didn't at all.
Ok, if you thought that was weird, here comes the really weird stuff. The rear windows started working - ANYTIME AT ALL - even with the key removed from the ignition. Then, tragically, the new (used) ECU I bought failed, and the front windows were stuck down. So, I hot-wired the motors on both (yes, with a 12V converter), just so they would stay up. Out of no where, as the wife was driving, the hazard lights came on and flashed continuously. The fuse for the turn signals had blown, so I replaced it and -WHAM!- the fuse blew, the windows rolled down on their own and the hazard flashers came back on. I had to disconnect the battery, and duct tape plastic to keep the weather (and cats and everything else) out, while I waited for a new ECU. This I installed yesterday, but, alas, the front windows still do not roll down. The rear windows do, but thankfully will not with the ignition off, and the hazards have stopped, so I got that going for me...All the fuses are their correct values and not blown.
I don't have the means or money to take it to the dealer, so any insight provided would be greatly appreciated. Should I try soldering this new one? Should I ask for a replacement from the parts distributor? Why Land Rover, why?
devongrant is offline   Reply With Quote
Old 10-31-2009, 02:57 PM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
From memory the ECU only controls the rear windows. The front windows are a more straight forward relay system.
Old 11-01-2009, 07:08 AM   #3 (permalink)
Ok, that's the first I'd heard of that. Any idea where the relay(s) may be?
Old 11-03-2009, 07:56 AM   #4 (permalink)
i believe the front window relays are located behind the glovebox where the window ecu is.
deeb is offline   Reply With Quote
Old 11-05-2009, 12:18 AM   #5 (permalink)
Steve_NZ
My drivers window would not operate. I discovered that it was most likely the Window ECU with 'dry' joints. I removed the circuit board and had it professionally soldered. Windows work fine now. Note that there are two relays on the board, but I only presume they are for the front window. As I understand things, the power supply to the rear windows goes via the Window ECU, so I guess its a good central point to look if any of the windows don't operate. One test you can do is to remove the centre console switches and swap them around to see if they have any effect on the windows operation. It is not too difficult to disassemble each switch and clean the contacts. Hope this is of some help.
Steve_NZ is offline   Reply With Quote
rr v8 4.4 nikasil problem???? please help. 2002hse Range Rover P38, Mk III and Range Rover Sport 3 09-12-2009 05:37 PM
Old Man EMU 3" Lift Rear Shock Problem lrrookie Discovery Series I 0 04-25-2009 11:32 AM
help I need a window guide antonpayne Discovery Series II 2 09-03-2008 02:37 PM
rr v8 4.4 nikasil problem???? please help. 2002hse General Land Rover Discussion 4 10-19-2005 02:00 PM
Problem with the window wipers JP-NORWAY Defender 2 09-02-2004 10:06 PM
