Old 12-03-2006, 04:39 PM   #1 (permalink)
Default Window noise
My 96 LR SE7 passenger window makes squeaking noises when rolling up. Should I put some oil inside it or will that make things worse?
"DO YOUR DUTY IN ALL THINGS. YOU CANNOT DO MORE. YOU SHOULD NEVER WISH TO DO LESS." GENERAL ROBERT E. LEE
Rebelman is offline   Reply With Quote
Old 12-03-2006, 06:41 PM   #2 (permalink)
The plastic roller on the window regulator is about to break, I would siggest you not use the window till you are ready to replace the regulator.
Old 12-03-2006, 09:01 PM   #3 (permalink)
drewclare25's Avatar
i don't mean to hijack the thread, but my passenger front window when it gets to the top, it seems like it slips a gear, falls a little bit, goes back up, falls...it pops each time it does this...is that the regulator going?
Best 4x4xFar
97 Green D1
3" BB springs
pro comp es9000 shocks
32x11.50 BFG Mud Terrains
15" american racing steel wheels
flowmaster 40 series dual pipes
mantec snorkel
drewclare25 is offline   Reply With Quote
Old 12-04-2006, 03:48 PM   #4 (permalink)
Thanks. Can I fix this myself or will a dealership mechanic have to do it?
Old 12-05-2006, 09:05 AM   #5 (permalink)
pavel's Avatar
Do it yourself - follow the description in the Haynes manual, it is straight forward
Old 12-05-2006, 02:55 PM   #6 (permalink)
Thanks. Stupid me, I did not take the time to check the book.
