Rocky Mountain High
![]() Join Date: Sep 2005
1994 Disco......
Has good spark....good fuel pressure...is getting plenty of air flow..... timeing is on(from what I was able to do on the side of a road) Cranks but no start... Any ideas? Tried to push start it..... No luck there...wouldn't keep going..... Thanks, Aaron |
Banned
If you have spark and fuel, the only thing your lacking is compression....
Check the rotor button and distributor cap real good. Could water have entered the distributor cap any time in the last little bit? Might also check that little module next to the distributor. |
#3 (permalink) | |
Rocky Mountain High
check the wires, many times i have myself mistaken where they go conected. on my disco when that happens, i just leave it overnight with the hood open and everything disconnected, battery, cables, plugs, anything electrical. and the morning after it starts.
#5 (permalink) | |
I just read that if your MAF sensor isn't working then there is a shutoff at 550 rpm. I don't know if this has anything to do with your problem, but thought I'd mention it.
Wade Location: Texas |
#7 (permalink) | |
Mike |
(Below is from RAVE..but I agree with Mike that it probably isn't the problem. This is for the D1, hotwire MAF.)
Mass air flow sensor (MAF Sensor) The ’hot wire’ type mass air flow sensor is mounted rigidly to the air filter and connected by flexible hose to the plenum chamber inlet. The sensing element of the MAF Sensor is a hot wire anenometer consisting of two wires, a sensing wire which is heated and a compensating wire which is not heated. Air flows across the wires cooling the heated one, changing its resistance. The ECM measures this change in resistance and calculates the amount of air flowing into the engine. As there is no default strategy, failure will result in the engine starting, and dying when it reaches 550 rev/min, when the ECM detects no MAF Sensor signal. The fault is indicated by illumination of the malfunction indicator light (MIL) on North American specification vehicles.
#10 (permalink) |
The more I learn about the two models, the more it appears the DII was a definite improvement. The cooling fans do not run all the time and burn out and if the MAF sensor goes out, you aren't stuck. I think the ignition is an improvement also from what I've read. Hmmm...I don't want to get rid of my D1, but maybe a DII to keep it company...
#13 (permalink) | |
I am at a loss as to what could be causing this. Does the engine turn over at normal speed, evenily? Does it even try to start, have you tried to shot a little starter fluid into the engine while cranking? Have you pulled the cap and checked to make sure the timing chain hasn't jumped a couple of teeth throwing your timing way the hell off. With the rotor pointing at the # 1 plug wire is the #1 piston all the way to to the top. Good luck, Mike |
#15 (permalink) | |
Rocky Mountain High
I am gonna do that when I have free time this week!!....when i tried last everything cranked over at a normal pace..... It doesn't even studder though...I have more time to look at it thurs and fri..I will tear into it then!! |
